Tools
Introduction
Go to step 1 ↓It may come in handy to know how to replace or remove an illuminated light switch. It is a simple and quick process but there are some safety measures you must follow through with. Dealing with electricity is no joke so you will need to make sure to follow all the steps correctly including to turn off your circuit breaker and light switch before beginning any repairs. Use this guide to replace your light switch.
Turn off the power/circuit breaker.
Turn off the power switch where you will be working.
Remove the screws using a Phillips screwdriver to dismount the switch from the wall.
Use a circuit tester to test and make sure that the power is off. Use both ends of the circuit tester and go into the side of the switch into the wall. Connect the pointed ends of the tester and touch them to the screws attached to the side of the switch.
Remove the switch from the wall.
