Ideapad 3-17IAU7 Memory Replacement
    1. Ideapad 3-17IAU7 Memory Replacement, Removing Bottom Case: step 1, image 1 of 1
      • Please turn off the device before opening the device
      • Remove the ten screws as shown in picture
      • The four bottom screws are different length for the other screws! (Blue Circle)
      • Remove the bottom case using a guitar pick
      Ask FixBot
    2. Ideapad 3-17IAU7 Memory Replacement, Removing the memory module: step 2, image 1 of 2 Ideapad 3-17IAU7 Memory Replacement, Removing the memory module: step 2, image 2 of 2
      • Remove the cable buy pushing the connector using the spudger (Red Circle)
      • Remove the Memory protective by using a pry tool (yellow rectangle)
      • After removing the memory protective push the silver tabs using a spudger (blue rectangle)
      • Remove the memory module.
      Ask FixBot
    3. Ideapad 3-17IAU7 Memory Replacement, Installing Memory module: step 3, image 1 of 1
      • Insert the new module according to the pin array
      • Push gently on the module until the two tabs are locked. (Locking the module)
      Ask FixBot
2 other people completed this guide.
Attached Documents
Ilia Tocheny
1,880 Reputation
9 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 30
Past 30 Days: 99
All Time: 948
