Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Parts
Tools
Introduction
Go to step 1 ↓If your Lenovo IdeaPad L340-15API overheats quickly, runs slowly, makes loud grinding or whirring noises, or experiences sudden shutdowns or restarts, the cooling fan may need to be replaced.
This guide walks you through replacing the fan in a Lenovo IdeaPad L340-15API, which helps regulate the device’s internal temperature and prevent overheating.
Before you begin the repair, power off the laptop and disconnect the charging adapter and any external peripherals.
Use a Phillips #1 screwdriver to remove the twelve 7.5 mm screws from the back cover.
Before you remove the fan, you need to remove the heatsink. The heatsink is the long copper piece connected to the fan.
Use a Phillips #1 screwdriver to loosen the four captive screws holding the heatsink in place.
Gently lift the heatsink and set it aside for reassembly later.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
