Up to 20% off select tools
IdeaPad L340-15API Battery Replacement
Views: 1K
View statistics:
Past 24 Hours:
12
Past 7 Days:
46
Past 30 Days:
196
All Time:
1,003
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 25 minutes
Difficulty: Easy
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Parts
Tools
Introduction
Go to step 1 ↓
The battery is a critical component that keeps your device powered. It supplies energy to all parts of the laptop and must hold a charge long enough to make the device portable.
If your laptop can’t hold a charge or must remain plugged in to stay on, the battery is likely the cause.
This guide shows how to replace the battery in a Lenovo IdeaPad L340-15API.
Before you begin, power off the laptop and disconnect the charging adapter and any external peripherals.
    1. IdeaPad L340-15API Battery Replacement, Optical Drive: step 1, image 1 of 2 IdeaPad L340-15API Battery Replacement, Optical Drive: step 1, image 2 of 2
      • Before beginning the repair, make sure that the device is fully powered off.
      • Turn the laptop over so the bottom cover is facing up.
      • The small screw hole near the center of the case, marked with a tiny DVD icon and an arrow, secures the optical drive.
      Ask FixBot
    2. IdeaPad L340-15API Battery Replacement: step 2, image 1 of 2 IdeaPad L340-15API Battery Replacement: step 2, image 2 of 2
      • Use a Phillips #1 screwdriver to remove the 7.5 mm screw securing the optical drive.
      • Place the screw down safely in a container/magnet strip where it will not get lost while you are working. These screws are very small and easily misplaced.
      Ask FixBot
    3. IdeaPad L340-15API Battery Replacement: step 3, image 1 of 2 IdeaPad L340-15API Battery Replacement: step 3, image 2 of 2
      • Place your thumb at the seam between the optical drive and the device.
      • Gently pull the component straight out from the device, taking care not to pull at an angle.
      Ask FixBot
    1. IdeaPad L340-15API Battery Replacement, Battery: step 4, image 1 of 2 IdeaPad L340-15API Battery Replacement, Battery: step 4, image 2 of 2
      • Use a Phillips #1 screwdriver to remove the twelve 7.5 mm screws from the back cover.
      Ask FixBot
    2. IdeaPad L340-15API Battery Replacement: step 5, image 1 of 3 IdeaPad L340-15API Battery Replacement: step 5, image 2 of 3 IdeaPad L340-15API Battery Replacement: step 5, image 3 of 3
      • Insert a plastic opening pick in the back left corner and wedge the panel open.
      • Slide the pick around the edge of the laptop to release the clips as you lift the panel.
      • If the opening pick isn’t working, use the iFixit opening tool to gain more leverage.
      • Remove the bottom cover.
      Ask FixBot
    3. IdeaPad L340-15API Battery Replacement: step 6, image 1 of 2 IdeaPad L340-15API Battery Replacement: step 6, image 2 of 2
      • Use the Phillips #1 screwdriver to remove the five 6.5 mm screws securing the battery.
      • Use a container/magnet strip to store the screws while working.
      Ask FixBot
    4. IdeaPad L340-15API Battery Replacement: step 7, image 1 of 3 IdeaPad L340-15API Battery Replacement: step 7, image 2 of 3 IdeaPad L340-15API Battery Replacement: step 7, image 3 of 3
      • Use the wide end of a spudger to push the connector tab, sliding the battery connector out of its socket.
      • It may take a lot of force to disconnect the cable. Go slowly, and don't pull on the cables.
      Ask FixBot
    5. IdeaPad L340-15API Battery Replacement: step 8, image 1 of 1
      • Remove the battery from the laptop.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
For optimal performance, calibrate your newly installed battery after completing this guide.
Author
with
Ian
347 Reputation
2 Guides authored
UMass Dartmouth, Team 2-5, Bowman Fall 2025 Member of UMass Dartmouth, Team 2-5, Bowman Fall 2025
UMASSD-BOWMAN-F25S2G5
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 12
Past 7 Days: 46
Past 30 Days: 196
All Time: 1,003
