IT-8800 -8500 Footrest Disassembly
View statistics:
Past 24 Hours:
Past 7 Days:
13
Past 30 Days:
74
All Time:
418
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 hour
Difficulty: Difficult
Community-Contributed Guide
Introduction
Go to step 1 ↓
All Screws in here will be color coded , example : Red and Orange on the same step means there are 2 different types of screws on that step.
Tools
    1. IT-8800 -8500 Footrest Disassembly, Footrest: step 1, image 1 of 1
      • Remove 8 screws marked in red .
      • NOTE: THERE IS 2 PIECES THAT ACT AS ONE COVER. DO NOT SLIDE OR PRY THESE PIECES APART FROM EACH OTHER IT WILL RESULT IN DAMAGE.
      • Remove 3 screws marked in Orange
      Ask FixBot
    2. IT-8800 -8500 Footrest Disassembly: step 2, image 1 of 1
      • Remove the 4 bolts and lock washers.
      Ask FixBot
    3. IT-8800 -8500 Footrest Disassembly: step 3, image 1 of 1
      • From here the lower piece will be free from the frame .
      • Air hose will then be disconnected from the nozzle marked with an arrow. Then unplug the three wires from the relay PCB.
      • Mounted here will be a screw threaded through 2 plastic holders . remove the screw and don't lose the plastic holders.
      Ask FixBot
    4. IT-8800 -8500 Footrest Disassembly: step 4, image 1 of 1
      • Unzip the the zipper marked with a red line. This will completely disconnect the upper assembly from the lower assembly.
      • Note in this photo the frame has been completely removed . NO need to do that for this repair.
      Ask FixBot
    5. IT-8800 -8500 Footrest Disassembly: step 5, image 1 of 1
      • Remove 2 screws and 2 washers for each foot pad.
      • EACH OF THESE FOOT PADS HAVE 2 WASHERS ON ONE END , THIS SERVES A PURPOSE . DON'T FORGET THIS DURING REASSEMBLY
      Ask FixBot
    6. IT-8800 -8500 Footrest Disassembly: step 6, image 1 of 1
      • Unzip the the leather from the bottom
      • The zippers sometimes don't have a zipper handle, please use a large paper clip.
      • Once leather is unzipped this is what you should see . Go ahead and remove the entire leather cover .
      Ask FixBot
    7. IT-8800 -8500 Footrest Disassembly: step 7, image 1 of 1
      • Remove the 6 screws on the top cover .
      • This foam is glued to the plastic . Do your best not to rip it , use a sharp blade to avoid any tearing.
      • Pro Tip: No need to peel this entire piece off . Just peel the edges and leave center glued .
      Ask FixBot
    8. IT-8800 -8500 Footrest Disassembly: step 8, image 1 of 1
      • Remove the 6 screws.
      • This cover will not come off until the top cover is removed first. Additionnally follow the same rule , keep the middle glued and peel back the edges
      Ask FixBot
    9. IT-8800 -8500 Footrest Disassembly: step 9, image 1 of 1
      • Remove the 4 bolts .
      • RECOMMENDED: USE A MAGNETIC TIP SCREW DRIVER FOR THIS STEP. OTHERWISE THOSE BOLTS CAN AND WILL FALL INTO THE HOLLOW FRAME PIECE
      Ask FixBot
    10. IT-8800 -8500 Footrest Disassembly: step 10, image 1 of 1
      • Remove the 4 bolts in each corner .
      • RECOMMENDED: USE A MAGNETIC TIP SCREW DRIVER FOR THIS STEP. OTHER WISE THOSE BOLTS CAN AND WILL FALL INTO THE HOLLOW FRAME PIECE
      Ask FixBot
    11. IT-8800 -8500 Footrest Disassembly: step 11, image 1 of 2 IT-8800 -8500 Footrest Disassembly: step 11, image 2 of 2
      • unplug motor wire.
      • Unscrew grounding wire. Be sure to reuse this screw and washer if new assembly did not include one.
      Ask FixBot
    12. IT-8800 -8500 Footrest Disassembly: step 12, image 1 of 1
      • YOU ARE DONE
      Ask FixBot
PLEASE REMEMBER THE FOLLOWING DURING REASSEMBLY:
- When gluing the foam to the plastic DON'T over do it , just spray for a second on the desired area and press foam onto glue.
- When Gluing the foam be sure your edges are smooth and everything is secured , other wise you will get bumps in the leather .
- There will be wrinkles on the leather when its re stretched , this is normal . They usually dissipate over time.
- If the Bolts from step 2 will not go on use a utility knife and cut X shaped holes on the leather until you can physically see the thread .
- When attaching the 3 wires and 1 hose from step 3 BE SURE these are not getting pinched between the upper and lower portion. Otherwise you will get no air to the feet area.
Good Luck .
Nick
2,764 Reputation
16 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 74
All Time: 418
