IKEA Drill Battery Replacement
Views: 17K
View statistics:
Past 24 Hours:
20
Past 7 Days:
89
Past 30 Days:
340
All Time:
16,761
Comments: 6
1 comment on steps, 5 guide comments.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 40 minutes
Difficulty: Difficult
Introduction
Go to step 1 ↓
The requirements for replacing the battery are the usage of a 4 mm Phillips screwdriver, a soldering iron station, a utility knife, heat shrink tubes and two lithium batteries (3.6 V). Make sure how to use a soldering iron, especially in combination with batteries. If you are not familiar with (replacing) batteries, it might be a good idea to search for some information about how batteries work. Last but not least, create a work environment with good lighting and a clean desk. The replacement requires attention and concentration.
Parts
Tools
    1. IKEA Drill Battery Replacement, Battery: step 1, image 1 of 1
      • Use a 4 mm Phillips screwdriver to remove the seven screws to disassemble the housing of the drill.
      Ask FixBot
    2. IKEA Drill Battery Replacement: step 2, image 1 of 1
      • Remove the sticker carefully from the bottom.
      Ask FixBot
    3. IKEA Drill Battery Replacement: step 3, image 1 of 1
      • Open the housing of the drill.
      • While opening place the rotation switch apart.
      • Detach the electric circuit and place it next to the drill.
      Ask FixBot
    4. IKEA Drill Battery Replacement: step 4, image 1 of 1
      • Cut each tubing from the three wires of the battery with a utility knife.
      Ask FixBot
    5. IKEA Drill Battery Replacement: step 5, image 1 of 2 IKEA Drill Battery Replacement: step 5, image 2 of 2
      • Disconnect the three wires of the battery with a soldering iron.
      Ask FixBot
    6. IKEA Drill Battery Replacement: step 6, image 1 of 1
      • Place each new tubing (three in total) on the battery wires through sliding them on each wire.
      Ask FixBot
    7. IKEA Drill Battery Replacement: step 7, image 1 of 1
      • Attach the two batteries to each other with tape, in case you have two separate batteries.
      • Use solder and a solder iron to attach the new battery to the wires.
      • The black wire should be connected with the negative pole of the two-wire side.
      • The wire should be warm enough to solder the battery to the wire.
      • Slide the tubings on each connection and heat each tubing with a lighter to make them shrink.
      Ask FixBot
    8. IKEA Drill Battery Replacement: step 8, image 1 of 1
      • Place the electric circuit and the rotation switch back into the housing.
      Ask FixBot
    9. IKEA Drill Battery Replacement: step 9, image 1 of 1
      • Put the housing back on the drill through clicking and closing it.
      • Put the seven screws back into the housing with the Phillips screwdriver.
      Ask FixBot
Finish Line
4 other people completed this guide.
5 Guide Comments
The difficult and dangerous operation is the tag connection to the Li-ion battery case. The Weller soldering iron shown in (7) has the wrong shape solder tip. The connection to a Li-ion must be made quickly and without significant heating of the Li-ion. Connections are usually spot welded but an amateur could try a solder gun.
The replacement batteries should be Li-ion size 18650 of at least 1500 mAh and identical. These are available with tags already attached and I would buy these and crimp to the tags. I have not done this myself because I found the receipt and the drill was bought 3 years ago so it is going back. The batteries were manufactured 4 years before I bought the drill so they were old when I bought it.
kaydee - Reply Share
Anyone know where I can get new brushes for the motor? Or a motor itself? Everything else works fine on my now 12 year old drill!
Charlie Nancarrow - Reply Share
Where can I buy the these battery
Dragons International Trading - Reply Share
Kenapa bor dicasindikat
SNIPER NGAPRAK - Reply Share
Where I can find charging pcb?
Rahul - Reply Share
Past 24 Hours: 20
Past 7 Days: 89
Past 30 Days: 340
All Time: 16,761
