Introduction
Use this guide to replace the left and right joystick modules on your IINE Retro Pocket game controller.
Set the controller down on your working surface.
Flip the controller over so the back of the controller is facing up, with the shoulder buttons facing away from you.
Use a Phillips #1 screwdriver to remove the four black 7.5mm screws from the corners of the back plate.
Use the tip of an opening pick to separate the back plate. Start at the bottom corner, and pry downwards.
As you make your way toward the center, you will eventually disengage the retaining clips located on either side of the status LED array.
Lift the back plate up and away from you, and set it aside.
Locate the battery connector.
Use a pair of tweezers to carefully push on the notches of the battery connector and disconnect it from the socket.
Locate the ZIF connector of the right joystick.
Use a pair of tweezers to flip up the black flap of the ZIF connector and unlock it.
Disconnect the joystick cable by carefully pulling it straight out of the connector.
Use a Phillips #00 screwdriver to remove the two black 3.5mm screws that secure the right joystick.
Locate the ZIF connector of the left joystick.
Use a Phillips #00 screwdriver to remove the two black 3.5mm screws that secure the left joystick.
Once the controller is fully reassembled, connect it to your Nintendo Switch and calibrate the new joystick.
2 other people completed this guide.
