IFYOO ZD-V108 D-pad Replacement
  1. IFYOO ZD-V108 D-pad Replacement, D-pad: step 1, image 1 of 3 IFYOO ZD-V108 D-pad Replacement, D-pad: step 1, image 2 of 3 IFYOO ZD-V108 D-pad Replacement, D-pad: step 1, image 3 of 3
    • Remove the seven 9.2 mm screws from the back of the controller using a Phillips #00 screwdriver.
    • Remove the back cover.
    Ask FixBot
  2. IFYOO ZD-V108 D-pad Replacement: step 2, image 1 of 2 IFYOO ZD-V108 D-pad Replacement: step 2, image 2 of 2
    • Remove the two 7.2 mm screws that connect the red daughterboard to the tan motherboard using a Phillips #00 screwdriver.
    Ask FixBot
  3. IFYOO ZD-V108 D-pad Replacement: step 3, image 1 of 3 IFYOO ZD-V108 D-pad Replacement: step 3, image 2 of 3 IFYOO ZD-V108 D-pad Replacement: step 3, image 3 of 3
    • Carefully pull up on the motherboard until it slides off from the four black cylinders keeping it in place.
    Ask FixBot
  4. IFYOO ZD-V108 D-pad Replacement: step 4, image 1 of 3 IFYOO ZD-V108 D-pad Replacement: step 4, image 2 of 3 IFYOO ZD-V108 D-pad Replacement: step 4, image 3 of 3
    • Remove the D-pad module on the right side of the controller.
    Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 39
All Time: 327
