IFYOO ZD-V108 Analog Stick Covers Replacement
  1. IFYOO ZD-V108 Analog Stick Covers Replacement, Analog Stick Covers: step 1, image 1 of 3 IFYOO ZD-V108 Analog Stick Covers Replacement, Analog Stick Covers: step 1, image 2 of 3 IFYOO ZD-V108 Analog Stick Covers Replacement, Analog Stick Covers: step 1, image 3 of 3
    • Remove the seven 9.2 mm screws from the back of the controller using a Phillips #00 screwdriver.
    • Remove the back cover.
    Ask FixBot
  2. IFYOO ZD-V108 Analog Stick Covers Replacement: step 2, image 1 of 2 IFYOO ZD-V108 Analog Stick Covers Replacement: step 2, image 2 of 2
    • Remove the two 7.2 mm screws that connect the red daughterboard to the tan motherboard using a Phillips #00 screwdriver.
    Ask FixBot
  3. IFYOO ZD-V108 Analog Stick Covers Replacement: step 3, image 1 of 3 IFYOO ZD-V108 Analog Stick Covers Replacement: step 3, image 2 of 3 IFYOO ZD-V108 Analog Stick Covers Replacement: step 3, image 3 of 3
    • Gently flip up the daughterboard until the blue analog stick covers become visible.
    • Be cautious when flipping up the daughterboard as it is very fragile.
    • Gently pull on the analog stick covers until they pop off.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 7
Past 30 Days: 33
All Time: 352
