Up to 20% off select tools
IBM Thinkpad T61 RAM Replacement
Views: 11K
View statistics:
Past 24 Hours:
4
Past 7 Days:
26
Past 30 Days:
128
All Time:
10,697
Comments: 0
Go to guide comments
Completed: 15
15 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Easy
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Parts
Tools
Introduction
Go to step 1 ↓
Replacing the RAM in this laptop is a relatively straightforward process.
    1. IBM Thinkpad T61 RAM Replacement, Battery: step 1, image 1 of 1
      • Ensure the laptop has been properly shut down and unplugged.
      • Turn the computer over so that you can see the battery release tab located near the top of the Thinkpad.
      Ask FixBot
    2. IBM Thinkpad T61 RAM Replacement: step 2, image 1 of 1
      • Use your finger to slide the release tab to the unlocked symbol.
      Ask FixBot
    3. IBM Thinkpad T61 RAM Replacement: step 3, image 1 of 3 IBM Thinkpad T61 RAM Replacement: step 3, image 2 of 3 IBM Thinkpad T61 RAM Replacement: step 3, image 3 of 3
      • Hold the tab in the unlocked position and push the battery away from the computer to remove it.
      Ask FixBot
    4. IBM Thinkpad T61 RAM Replacement: step 4, image 1 of 1
      • Slide the new battery in until it clicks.
      • Ensure that the release tab is in the locked position.
      Ask FixBot
    1. IBM Thinkpad T61 RAM Replacement, RAM: step 5, image 1 of 1
      • Using a #0 Phillips screwdriver, remove four 17.0mm screws on the back of the computer.
      • These screws have a RAM symbol next to them.
      Ask FixBot
    2. IBM Thinkpad T61 RAM Replacement: step 6, image 1 of 1
      • Flip back over and open the laptop.
      • Lift up on the inside front panel just below the edge of the keyboard.
      Ask FixBot
    3. IBM Thinkpad T61 RAM Replacement: step 7, image 1 of 1
      • The green rectangles under the front panel are the RAM.
      Ask FixBot
    4. IBM Thinkpad T61 RAM Replacement: step 8, image 1 of 3 IBM Thinkpad T61 RAM Replacement: step 8, image 2 of 3 IBM Thinkpad T61 RAM Replacement: step 8, image 3 of 3
      • Press out on the two tabs on either side of the ram at the same time.
      • The RAM will release and pop up at a 25 degree angle.
      Ask FixBot
    5. IBM Thinkpad T61 RAM Replacement: step 9, image 1 of 1
      • Pull the RAM away from the housing to remove.
      Ask FixBot
15 other people completed this guide.
Author
with
Kyle
479 Reputation
4 Guides authored
Cal Poly, Team 8-58, Johann Spring 2013 Member of Cal Poly, Team 8-58, Johann Spring 2013
CPSU-JOHANN-S13S8G58
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 26
Past 30 Days: 128
All Time: 10,697
