IBM Thinkpad T60 Wireless Card Replacement
Views: 7.1K
View statistics:
Past 24 Hours:
Past 7 Days:
23
Past 30 Days:
135
All Time:
7,054
Comments: 4
4 comments on steps.
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 20 minutes
Difficulty: Moderate
Needs More Images
A few more images would make this guide's procedures crystal clear.
Introduction
Go to step 1 ↓
This guide shows how to remove a previously existing wireless card. Be sure you are comfortable with the palm rest and keyboard removal guides before attempting this guide. Remember to always power down the computer before attempting any installation/removal of any hardware components. Be sure to remove the AC adapter and all cables from the computer. If the computer has been on, wait several minutes before beginning the procedure to ensure all parts have cooled down.
Tools
    1. IBM Thinkpad T60 Wireless Card Replacement, Battery: step 1, image 1 of 1
      • Turn the computer over to see the small tab on the battery located near the top of the Thinkpad.
      • Use your finger to slide the tab to the right to unlock the battery.
      Ask FixBot
    2. IBM Thinkpad T60 Wireless Card Replacement: step 2, image 1 of 2 IBM Thinkpad T60 Wireless Card Replacement: step 2, image 2 of 2
      • Once the tab is in the unlocked position (far right), pull the battery outwards away from the Thinkpad.
      • The battery is now disconnected.
      Ask FixBot
    1. IBM Thinkpad T60 Wireless Card Replacement, Palm Rest: step 3, image 1 of 2 IBM Thinkpad T60 Wireless Card Replacement, Palm Rest: step 3, image 2 of 2
      • Using a #0 Phillips screwdriver, remove the four 17.0 mm screws.
      Ask FixBot
    2. IBM Thinkpad T60 Wireless Card Replacement: step 4, image 1 of 1
      • Turn the computer back over, so the keyboard is facing upwards.
      • Open the display to access the palm rest. Apply pressure to the sides of the palm rest so that it bends upwards in the middle. Gently lift away from the computer.
      Ask FixBot
    3. IBM Thinkpad T60 Wireless Card Replacement: step 5, image 1 of 2 IBM Thinkpad T60 Wireless Card Replacement: step 5, image 2 of 2
      • Slightly lift the palm rest away from the computer.
      • The touchpad's data cable connects the palm rest to the base unit. BE CAREFUL!
      • Detach the connector by pulling upwards on the white tab.
      Ask FixBot
    1. IBM Thinkpad T60 Wireless Card Replacement, Keyboard: step 6, image 1 of 2 IBM Thinkpad T60 Wireless Card Replacement, Keyboard: step 6, image 2 of 2
      • Turn the Thinkpad over so you can see the bottom.
      • Using a #0 Phillips screwdriver, remove the 17.0 mm screw.
      Ask FixBot
    2. IBM Thinkpad T60 Wireless Card Replacement: step 7, image 1 of 2 IBM Thinkpad T60 Wireless Card Replacement: step 7, image 2 of 2
      • First, flip the laptop back over. Next, use your fingers to pry the keyboard upwards slightly.
      • Lift the keyboard until you are able to see the wire connection
      Ask FixBot
    3. IBM Thinkpad T60 Wireless Card Replacement: step 8, image 1 of 2 IBM Thinkpad T60 Wireless Card Replacement: step 8, image 2 of 2
      • Pull upwards on the connector to disconnect the keyboard.
      • The keyboard is now disconnected.
      Ask FixBot
    1. IBM Thinkpad T60 Wireless Card Replacement, Wireless Card: step 9, image 1 of 2 IBM Thinkpad T60 Wireless Card Replacement, Wireless Card: step 9, image 2 of 2
      • Using a #0 Phillips screwdriver, remove the two 10.5 mm screws.
      Ask FixBot
    2. IBM Thinkpad T60 Wireless Card Replacement: step 10, image 1 of 2 IBM Thinkpad T60 Wireless Card Replacement: step 10, image 2 of 2
      • Disconnect the two connectors by pulling upwards on the base of the grey and black cables.
      Ask FixBot
    3. IBM Thinkpad T60 Wireless Card Replacement: step 11, image 1 of 1
      • Grasp the sides of the card and pull perpendicular to the slot.
      • The wireless card is now disconnected.
      Ask FixBot
4 other people completed this guide.
Cody Kratochvil
581 Reputation
5 Guides authored
Cal Poly, Team 7-9, Maness Winter 2013 Member of Cal Poly, Team 7-9, Maness Winter 2013
CPSU-MANESS-W13S7G9
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 23
Past 30 Days: 135
All Time: 7,054
