Up to 20% off select tools
IBM Thinkpad T60 RAM Replacement
Views: 17K
View statistics:
Past 24 Hours:
4
Past 7 Days:
28
Past 30 Days:
122
All Time:
16,766
Comments: 5
5 comments on steps.
Completed: 17
17 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Moderate
Needs More Images
A few more images would make this guide's procedures crystal clear.
Parts
Tools
Introduction
Go to step 1 ↓
This guide will show how to remove and replace the RAM of the IBM Thinkpad T60. Remember to always power down the computer before attempting any installation/removal of any hardware components. Be sure to remove the AC adapter and all cables from the computer. If the computer has been on, wait several minutes before beginning the procedure to ensure all parts have cooled down.
    1. IBM Thinkpad T60 RAM Replacement, Battery: step 1, image 1 of 1
      • Turn the computer over to see the small tab on the battery located near the top of the Thinkpad.
      • Use your finger to slide the tab to the right to unlock the battery.
      Ask FixBot
    2. IBM Thinkpad T60 RAM Replacement: step 2, image 1 of 2 IBM Thinkpad T60 RAM Replacement: step 2, image 2 of 2
      • Once the tab is in the unlocked position (far right), pull the battery outwards away from the Thinkpad.
      • The battery is now disconnected.
      Ask FixBot
    1. IBM Thinkpad T60 RAM Replacement, Palm Rest: step 3, image 1 of 2 IBM Thinkpad T60 RAM Replacement, Palm Rest: step 3, image 2 of 2
      • Using a #0 Phillips screwdriver, remove the four 17.0 mm screws.
      Ask FixBot
    2. IBM Thinkpad T60 RAM Replacement: step 4, image 1 of 1
      • Turn the computer back over, so the keyboard is facing upwards.
      • Open the display to access the palm rest. Apply pressure to the sides of the palm rest so that it bends upwards in the middle. Gently lift away from the computer.
      Ask FixBot
    3. IBM Thinkpad T60 RAM Replacement: step 5, image 1 of 2 IBM Thinkpad T60 RAM Replacement: step 5, image 2 of 2
      • Slightly lift the palm rest away from the computer.
      • The touchpad's data cable connects the palm rest to the base unit. BE CAREFUL!
      • Detach the connector by pulling upwards on the white tab.
      Ask FixBot
    1. IBM Thinkpad T60 RAM Replacement, RAM: step 6, image 1 of 2 IBM Thinkpad T60 RAM Replacement, RAM: step 6, image 2 of 2
      • Press out the two tabs on either side of the card at the same time.
      • The memory card will slide upwards at a 20 degree angle.
      Ask FixBot
    2. IBM Thinkpad T60 RAM Replacement: step 7, image 1 of 1
      • Remove the memory card from the slot by pulling perpendicular to the slot.
      Ask FixBot
17 other people completed this guide.
Author
with
Cody Kratochvil
590 Reputation
5 Guides authored
Cal Poly, Team 7-9, Maness Winter 2013 Member of Cal Poly, Team 7-9, Maness Winter 2013
CPSU-MANESS-W13S7G9
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 28
Past 30 Days: 122
All Time: 16,766
