IBM Thinkpad T60 Hard Drive Replacement
    1. IBM Thinkpad T60 Hard Drive Replacement, Hard Drive: step 1, image 1 of 1
      • Turn the Thinkpad over so you can see the back.
      • Locate this screw in the bottom left-hand corner.
      Ask FixBot
    2. IBM Thinkpad T60 Hard Drive Replacement: step 2, image 1 of 1
      • Using a #0 Phillips screwdriver, remove the 17.0 mm screw.
      Ask FixBot
    3. IBM Thinkpad T60 Hard Drive Replacement: step 3, image 1 of 1
      • Carefully remove the plastic piece covering the hard drive port by pulling perpendicular to the side of the laptop.
      Ask FixBot
    4. IBM Thinkpad T60 Hard Drive Replacement: step 4, image 1 of 2 IBM Thinkpad T60 Hard Drive Replacement: step 4, image 2 of 2
      • Use a small screwdriver to locate the black ribbon.
      • With the screwdriver, pull the black tab out of the slot.
      Ask FixBot
    5. IBM Thinkpad T60 Hard Drive Replacement: step 5, image 1 of 2 IBM Thinkpad T60 Hard Drive Replacement: step 5, image 2 of 2
      • Pull gently on the black ribbon and the metal tray carrying the hard drive will slide out.
      Ask FixBot
    6. IBM Thinkpad T60 Hard Drive Replacement: step 6, image 1 of 1
      • Remove the black plastic coverings on either side of the hard drive.
      • There is not a hard drive in this example, but the process is the same regardless.
      Ask FixBot
9 other people completed this guide.
Cody Kratochvil
581 Reputation
5 Guides authored
Cal Poly, Team 7-9, Maness Winter 2013 Member of Cal Poly, Team 7-9, Maness Winter 2013
CPSU-MANESS-W13S7G9
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 12
Past 30 Days: 72
All Time: 12,169
