Up to 20% off select tools
IBM Thinkpad 700C Disassembly
Views: 1.5K
View statistics:
Past 24 Hours:
2
Past 7 Days:
20
Past 30 Days:
118
All Time:
1,546
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 hour
Difficulty: Moderate
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
Need to repair an IBM Thinkpad 700C? Then this guide is for you. It uses lots of photos and thoroughly documents the sizes and types of screws used in each subassembly. This is particularly useful because the official service manual is full of errors.
    1. IBM Thinkpad 700C Disassembly, Screw Sizes: step 1, image 1 of 1
      • Screw sizes in this guide are given in millimeters. This is the length of the threads alone, not the head.
      • Actual screws are slightly shorter than the nominal length. (About 0.3mm)
      • All the machine screws are M2.5 Phillips head unless otherwise noted.
      Ask FixBot
    2. IBM Thinkpad 700C Disassembly, LED Indicator Cover: step 2, image 1 of 3 IBM Thinkpad 700C Disassembly, LED Indicator Cover: step 2, image 2 of 3 IBM Thinkpad 700C Disassembly, LED Indicator Cover: step 2, image 3 of 3
      • Open the laptop screen almost all the way.
      • Set the laptop on its side.
      • Using a spudger, unhook the LED cover's plastic tabs on the back of the laptop base.
      • The plastic is quite brittle and fragile. Be careful not to crack the tabs.
      • From the front of the laptop, pivot the LED indicator cover towards the keyboard and unhook the tabs on this side.
      Ask FixBot
    3. IBM Thinkpad 700C Disassembly, Hinge Covers: step 3, image 1 of 2 IBM Thinkpad 700C Disassembly, Hinge Covers: step 3, image 2 of 2
      • Remove the hinge covers on each end of the laptop using a guitar pick and a spudger tool.
      • There are three plastic latches you are trying to release. They are circled in red.
      • You may need to adjust the spudger and guitar pick position to release all the latches.
      • Repeat for the hinge cover on the opposite side.
      • The hinge covers are not interchangeable. The bevel on the front faces the keyboard.
      Ask FixBot
    4. IBM Thinkpad 700C Disassembly, Hinge Screws: step 4, image 1 of 3 IBM Thinkpad 700C Disassembly, Hinge Screws: step 4, image 2 of 3 IBM Thinkpad 700C Disassembly, Hinge Screws: step 4, image 3 of 3
      • Gently close the laptop. Use guitar picks or something to prop the front of the screen so the two latches don't engage.
      • The hinges are stiff enough to crack the plastic! You may need to push on and support the rear of the laptop while closing it to prevent the hinges from cracking the rear plastics.
      • Using your fingernail or a spudger, remove the two screw covers from the top.
      • Remove the four 3mm screws on the rear surface of the laptop securing the LCD hinge.
      • Remove the two 5mm silver-colored screws holding the top of the hinge to the base of the laptop.
      • When reassembling the laptop, put the longer screws in before the shorter screws.
      Ask FixBot
    5. IBM Thinkpad 700C Disassembly, LED Indicator Board: step 5, image 1 of 3 IBM Thinkpad 700C Disassembly, LED Indicator Board: step 5, image 2 of 3 IBM Thinkpad 700C Disassembly, LED Indicator Board: step 5, image 3 of 3
      • Unlatch the flex connector with a guitar pick or your fingernail, then gently pull the flex cable free.
      • Using a small PH00 Phillips bit from your screwdriver kit, loosen the screw holding the LED assembly in place.
      • The screw can stay in the assembly. The thin PH00 bit can sneak past the LED circuit board so you don't need to remove it.
      • Pull the LED indicator board free, unhooking it from the 4-wire cable (LCD backlight power)
      Ask FixBot
    6. IBM Thinkpad 700C Disassembly, Unplug the LCD Cables: step 6, image 1 of 3 IBM Thinkpad 700C Disassembly, Unplug the LCD Cables: step 6, image 2 of 3 IBM Thinkpad 700C Disassembly, Unplug the LCD Cables: step 6, image 3 of 3
      • Remove the 3mm screw holding the LCD data cable bracket in place.
      • Note the cable routing carefully. During reassembly, the cables must follow the exact same paths in order to get everything to fit.
      • Unplug the 4-pin LCD backlight power cable and the multicolor LCD data cable using a spudger.
      Ask FixBot
    7. IBM Thinkpad 700C Disassembly, LCD Panel Separation: step 7, image 1 of 2 IBM Thinkpad 700C Disassembly, LCD Panel Separation: step 7, image 2 of 2
      • Gently lift the laptop screen up, allowing the hinges to slide clear from the base, and set it aside.
      • Remove the two plastic hinge spacers resting on the laptop base.
      • The two hinge spacers are not interchangeable--be sure to note which one goes where.
      Ask FixBot
    8. IBM Thinkpad 700C Disassembly, LCD Panel Back Cover Removal: step 8, image 1 of 2 IBM Thinkpad 700C Disassembly, LCD Panel Back Cover Removal: step 8, image 2 of 2
      • Using a dental pick or small screwdriver, remove the two rubber plugs (blue circles)
      • With the dental pick or screwdriver, remove the two rubber disks (red circles) that cover up the screws.
      • Using a T6 Torx driver, remove the four 5mm screws formerly covered by the plugs and disks.
      • Flip the panel over face down, then lift up the back cover on the hinge side.
      • Slide the back cover forward to clear the lid latch hooks in the two front corners.
      • The cover should lift right off.
      Ask FixBot
    9. IBM Thinkpad 700C Disassembly, Flex Cables: step 9, image 1 of 2 IBM Thinkpad 700C Disassembly, Flex Cables: step 9, image 2 of 2
      • Remove the long flex cable (red box)
      • Note the exact orientation--the horizontal metal stripe (see the green box) is offset and must be reinstalled exactly the same way
      • Be careful with the flex connector latches which are quite fragile. Slide them parallel to the cable using a fingernail or a guitar pick.
      • Remove the two 90 degree flex cables (orange boxes), again being sure to record their exact orientation and location.
      • During reinstallation of the 90 degree cables, it is easier to install them in the top and bottom circuit boards first.
      • Disconnect the flex cable on the far right (blue box).
      Ask FixBot
    10. IBM Thinkpad 700C Disassembly, LCD Frame Stiffener: step 10, image 1 of 3 IBM Thinkpad 700C Disassembly, LCD Frame Stiffener: step 10, image 2 of 3 IBM Thinkpad 700C Disassembly, LCD Frame Stiffener: step 10, image 3 of 3
      • Remove the four 12mm screws in each corner of the panel (red circles)
      • Prop the corner of the frame up with a guitar pick and unhook the data cable, flipping it up on top of the frame.
      • Repeat for the LCD backlight power cable.
      • Lift the frame stiffener up and off the LCD panel.
      Ask FixBot
    11. IBM Thinkpad 700C Disassembly, LCD Backlight and LCD Driver Boards: step 11, image 1 of 3 IBM Thinkpad 700C Disassembly, LCD Backlight and LCD Driver Boards: step 11, image 2 of 3 IBM Thinkpad 700C Disassembly, LCD Backlight and LCD Driver Boards: step 11, image 3 of 3
      • Remove the four 6mm self-tapping screws securing both circuit boards.
      • Lift up and remove the LCD driver board (right).
      • Unplug the two small flex cables from the backlight board, being sure to properly unlatch the connectors first.
      • Flip the backlight power board over to the left, exposing the CCFL high voltage wires.
      • Disconnect the two CCFL high voltage wires.
      • The CCFL connectors can be challenging to remove. Try using a spudger to pry the connector+tiny board upwards while using your finger to pull sideways on the connector to disengage the latching tabs.
      • When replacing the backlight power board, be sure the two slider potentiometers engage with the plastic sliders on the front of the case.
      Ask FixBot
    12. IBM Thinkpad 700C Disassembly, CCFL Board Capacitors: step 12, image 1 of 1
      • While you have the CCFL board out, you will likely want to replace the leaky electrolytic capacitors.
      • C1: 220uF 35V radial leaded electrolytic, 10mm tall, 10.1mm dia. lead spacing 5mm. Mouser p/n: 581-REF1009221M035K
      • C2: 4.7uF 25V radial leaded electrolytic, 5.7mm tall, 4.1mm dia lead spacing 2mm. Mouser p/n: 667-ECE-A1EKS4R7I
      • C3: 33uF 6.3V radial leaded electrolytic, 5.7mm tall, 5.1mm dia lead spacing 2.5mm. Mouser p/n: 667-ECE-A1CKS330
      Ask FixBot
    13. IBM Thinkpad 700C Disassembly, LCD Driver Board Capacitors: step 13, image 1 of 1
      • Likewise, the LCD driver board typically needs capacitors replaced.
      • C1, C2: 22uF 35V SMD electrolytic 5.6mm tall, 6.25mm dia. Mouser p/n 667-EEE-HB1V220P
      • C3, C4: 47uF 25V SMD electrolytic 6.4mm tall, 8mm dia. Mouser p/n 667-EEE-HB1E470AP
      • C5: 100uF 16V SMD electrolytic 6.4mm tall, 8mm dia. Mouser p/n 667-EEE-HBE101UAP
      • Electrolyte leakage from the old capacitors may also damage the trimmer resistors. Both original parts are Panasonic EVM1U which is no longer available. You may be able to bodge wire modern trimmers.
      • R1: 20K ohm, typically set with the upper resistance at 6K and the lower resistance at 14K (metal cup side up, 3 leads to the right, 1 lead to the left.) Probably safe to replace them with individual resistors.
      • R2: 500 ohms set to the halfway point (250 ohms from center to each side)
      • Capacitor electrolyte is mildly acidic and can eat through traces and vias. Neutralize with baking soda and wash the board thoroughly before putting new parts in place. Check continuity of traces and vias in case you need to make more repairs.
      Ask FixBot
    14. IBM Thinkpad 700C Disassembly, Hinges: step 14, image 1 of 2 IBM Thinkpad 700C Disassembly, Hinges: step 14, image 2 of 2
      • Take out the two 8mm screws fastening the hinges in place.
      • Remove the hinges. They are not identical so keep track of which is which.
      • Quick hinge stiffness fix:
      • Place the hinge in a vise but do not tighten it down.
      • Rest the hinge on the bottom sheet metal without gripping the metal pin. The locking washer should be facing upwards.
      • Tap the top of the metal pin with a hammer to loosen up the hinge action.
      • If you loosen the hinge too much, take it out of the vise and place it on top of the vise. put a small hex driver over the top and tap it with a hammer to drive the locking washer back down.
      Ask FixBot
    15. IBM Thinkpad 700C Disassembly, LCD backlight (optional): step 15, image 1 of 1
      • Lift the plastic CCFL and diffuser assembly straight up and away. The upper and lower driver boards will need to be flex back and out of the way.
      • Do not allow the driver boards to slap back into the bare LCD panel as you remove the diffuser assembly.
      • Be clean--any dust or debris stuck to the LCD may show up on the front side.
      • Never clean an LCD panel with isopropyl alcohol as this may cause or aggravate "vinegar syndrome." Use distilled water or glass cleaner and a lint-free Kim wipe.
      Ask FixBot
    16. IBM Thinkpad 700C Disassembly, Battery and Hard Drive: step 16, image 1 of 3 IBM Thinkpad 700C Disassembly, Battery and Hard Drive: step 16, image 2 of 3 IBM Thinkpad 700C Disassembly, Battery and Hard Drive: step 16, image 3 of 3
      • Remove the battery by sliding the battery faceplate down then pulling the battery forward, out of the unit.
      • Set the hard drive cover switch to the unlocked position
      • Slide the hard drive cover forward, away from the unit.
      • With a fingernail, snag the blue bar on the front of the hard drive. Pull on it and the hard drive should disconnect and slide free.
      Ask FixBot
    17. IBM Thinkpad 700C Disassembly, Modem: step 17, image 1 of 3 IBM Thinkpad 700C Disassembly, Modem: step 17, image 2 of 3 IBM Thinkpad 700C Disassembly, Modem: step 17, image 3 of 3
      • Tilt the modem cover down.
      • Loosen the screw holding the modem in place with a flat screwdriver. It is a captive screw so it will not come out all the way.
      • Remove the modem cover by pulling forward from the left edge, and then pull it to the left to disengage it from the right hinge pin.
      • Snag the pull handle (wire) with a fingernail and pull the modem free of the unit.
      Ask FixBot
    18. IBM Thinkpad 700C Disassembly, Standby Battery: step 18, image 1 of 1
      • Unplug the standby battery connector with a spudger.
      • The standby battery is not otherwise held in place and should drop right out.
      Ask FixBot
    19. IBM Thinkpad 700C Disassembly, Memory Cover: step 19, image 1 of 1
      • Flip the laptop over and place it on several layers of bubble wrap to protect the fragile plastic hooks that retain the LED indicator cover and hinge covers.
      • The LED indicator cover and hinge cover plastic hooks are incredibly fragile.
      • Remove the memory cover by pushing it down and to the left.
      • You may need to use a guitar pick to give it a little encouragement.
      Ask FixBot
    20. IBM Thinkpad 700C Disassembly, Rear Cover: step 20, image 1 of 3 IBM Thinkpad 700C Disassembly, Rear Cover: step 20, image 2 of 3 IBM Thinkpad 700C Disassembly, Rear Cover: step 20, image 3 of 3
      • Remove three black 4mm screws.
      • Use guitar picks to dislodge 5 plastic latches around the perimeter (arrows)
      • There are two hidden plastic latches (arrows), one inside the hard drive slot, and the other between the floppy drive and the battery slot.
      • You may need to use a combination of a guitar pick and a spudger to dislodge the latch in the battery slot.
      • This step requires patience, sometimes latches can reconnect themselves, so you may want to leave the guitar picks in place until the cover is completely free.
      • Remove the cover and set it aside.
      Ask FixBot
    21. IBM Thinkpad 700C Disassembly, Video Card Shield: step 21, image 1 of 2 IBM Thinkpad 700C Disassembly, Video Card Shield: step 21, image 2 of 2
      • Remove two silver 5mm screws from the upper part of the video card shield.
      • Tilt the shield forward and slide it backwards to remove it.
      Ask FixBot
    22. IBM Thinkpad 700C Disassembly, CPU Card Assembly: step 22, image 1 of 3 IBM Thinkpad 700C Disassembly, CPU Card Assembly: step 22, image 2 of 3 IBM Thinkpad 700C Disassembly, CPU Card Assembly: step 22, image 3 of 3
      • Remove two silver 5mm screws from the CPU card.
      • Use a guitar pick to help pry the CPU card up and out of its connector, which is directly beneath the area with the screws.
      Ask FixBot
    23. IBM Thinkpad 700C Disassembly, Video Board: step 23, image 1 of 3 IBM Thinkpad 700C Disassembly, Video Board: step 23, image 2 of 3 IBM Thinkpad 700C Disassembly, Video Board: step 23, image 3 of 3
      • Remove the black 4mm screw above the parallel port.
      • Remove the silver 4mm screw from between the docking port and the VGA connector.
      • Pull straight up from the top left and right of the video card to unplug it from the planar (motherboard).
      Ask FixBot
    24. IBM Thinkpad 700C Disassembly, Memory Board: step 24, image 1 of 2 IBM Thinkpad 700C Disassembly, Memory Board: step 24, image 2 of 2
      • Remove the two 16mm screws from the memory card.
      • The plastic modem guide rail comes off with the two screws as well
      • Unplug the memory board from the planar and lift it away.
      Ask FixBot
    25. IBM Thinkpad 700C Disassembly, PS/2 Mouse Shield, Power Button, Coin Cell: step 25, image 1 of 2 IBM Thinkpad 700C Disassembly, PS/2 Mouse Shield, Power Button, Coin Cell: step 25, image 2 of 2
      • Push in on the plastic piece on the outside of the case next to the PS/2 mouse connector.
      • While maintaining pressure, slide the plastic part up to release the plastic latches. The part should come away.
      • Gently pull off the metal connector shield.
      • Lift the power switch slider up and away from the case.
      • Remove the coin cell using a spudger on its connector.
      Ask FixBot
    26. IBM Thinkpad 700C Disassembly, Planar Fasteners: step 26, image 1 of 3 IBM Thinkpad 700C Disassembly, Planar Fasteners: step 26, image 2 of 3 IBM Thinkpad 700C Disassembly, Planar Fasteners: step 26, image 3 of 3
      • Unlatch the floppy drive flex cable using a spudger.
      • Flip the laptop over and remove the slotted standoff next to the 4-pin LCD backlight power connector
      • Flip the laptop back over and remove the five screws holding the planar to the case. They are not all the same!
      • Nearest the power jack: 4mm black screw
      • Next to the parallel port: 3mm black screw
      • Right side of docking connector: 5mm silver screw
      • Above docking connector: 4mm black screw
      • Left of docking connector: 3mm black screw
      Ask FixBot
    27. IBM Thinkpad 700C Disassembly, Planar: step 27, image 1 of 3 IBM Thinkpad 700C Disassembly, Planar: step 27, image 2 of 3 IBM Thinkpad 700C Disassembly, Planar: step 27, image 3 of 3
      • Hold the thin plastic modem cover out of the way and, with your fingers, gently pry up the left edge of the planar.
      • Gently pull up on the right side of the planar.
      • Remove the planar slowly so you can see how the PC speaker is sitting underneath. Only the planar holds it in place against the keyboard driver board. See the reference image for the orientation of the cable and position of the rubber speaker bracket.
      Ask FixBot
    28. IBM Thinkpad 700C Disassembly, Power Board: step 28, image 1 of 3 IBM Thinkpad 700C Disassembly, Power Board: step 28, image 2 of 3 IBM Thinkpad 700C Disassembly, Power Board: step 28, image 3 of 3
      • Unscrew the black 8mm screw holding the battery holder clip in place. Remove both the screw and the clip
      • Remove the two silver 5mm screws on either side of the AC adapter power jack cover.
      • Remove the AC adapter power jack cover itself.
      • Lift out the power board and unplug it from the battery connector.
      • When reinstalling the power board, ensure the volume slide switch engages with the prongs on the front panel switch actuator. (red box)
      • Capacitor C18 (47uF 6.3V, 5mm dia, 6mm height) nearly always leaks on the power board and must be replaced. It can also cause extensive damage, etching out vias and traces. See my reverse engineered power board if you want to attempt a repair.
      Ask FixBot
    29. IBM Thinkpad 700C Disassembly, Keyboard and Trackpoint Controller: step 29, image 1 of 2 IBM Thinkpad 700C Disassembly, Keyboard and Trackpoint Controller: step 29, image 2 of 2
      • Remove the two black 3mm screws on the left and right sides of the board
      • Unplug the amber flex cable going to the trackpoint using a spudger.
      • Flip the board up and disconnect the two keyboard flex cables.
      Ask FixBot
    30. IBM Thinkpad 700C Disassembly, Floppy Drive: step 30, image 1 of 3 IBM Thinkpad 700C Disassembly, Floppy Drive: step 30, image 2 of 3 IBM Thinkpad 700C Disassembly, Floppy Drive: step 30, image 3 of 3
      • Insert two guitar picks into the metal latches on the left side of the floppy drive. They should go between the metal tab (red box) and the plastic case.
      • You may be able to use a spudger to help get the guitar picks in place.
      • Tilt up the left side of the floppy drive.
      • Pull the floppy drive diagonally to disengage the right side from the frame stiffener.
      • To reinstall the floppy drive, you may need to put a spudger halfway between the two guitar picks to get the sheet metal floppy bracket to clear a tab in the side of the plastic case.
      Ask FixBot
    31. IBM Thinkpad 700C Disassembly, Frame Stiffener: step 31, image 1 of 2 IBM Thinkpad 700C Disassembly, Frame Stiffener: step 31, image 2 of 2
      • Remove the frame stiffener by unscrewing the six screws.
      • Near power switch: 3mm black screw
      • Top, near hard drive slot: two 5mm silver screws
      • Top, near floppy drive opening: two 4mm black screws
      • Bottom, near power board: silver 6mm screw (note the unusual length compared to the other silver screws).
      • Ensure the small piece of amber kapton tape remains attached to the battery wires.
      Ask FixBot
    32. IBM Thinkpad 700C Disassembly, Keyboard: step 32, image 1 of 1
      • Remove the five screws from the keyboard and the trackpoint button stiffener plate.
      • Stiffener plate and upper right corner: three 4mm black screws
      • Upper left: 5mm silver screw
      • Lower center: 3mm black screw
      • Remove the trackpoint button stiffener plate
      • Remove the keyboard.
      Ask FixBot
    33. IBM Thinkpad 700C Disassembly, Complete: step 33, image 1 of 1
      • You are done!
      Ask FixBot
Author
with
Tube Time
643 Reputation
2 Guides authored
1 Guide Comment
Incase you're interested, I'm rebuilding the bezel around the keyboard from scratch to reinforce the rear hinge plastics, so 'refurbished' hinges can be re-attached and all the smashed up 700C machines can come back to life. If you'd like to know more, my handle on IG is solidpr0. Cheers
alex - Reply Share
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 118
All Time: 1,546
