Up to 20% off select tools
IBM ThinkPad t43 RAM Replacement
Views: 2.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
71
All Time:
2,087
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 - 3 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
Replacing or upgrading the RAM for the IBM T43 can give it a greater performance boost.
    1. IBM ThinkPad t43 RAM Replacement, RAM: step 1, image 1 of 3 IBM ThinkPad t43 RAM Replacement, RAM: step 1, image 2 of 3 IBM ThinkPad t43 RAM Replacement, RAM: step 1, image 3 of 3
      • To remove the cover, you will need to take out the single screw.
      • Unscrew until the cover comes off
      • Lift the cover from the edge and pull off
      • If the cover doesn't come right up and you have felt that you have unscrewed it, you can lift the cover and the screw will come off with it.
      Ask FixBot
    2. IBM ThinkPad t43 RAM Replacement: step 2, image 1 of 3 IBM ThinkPad t43 RAM Replacement: step 2, image 2 of 3 IBM ThinkPad t43 RAM Replacement: step 2, image 3 of 3
      • Place your hands on the clips and push on them outward until the RAM pops out
      Ask FixBot
    3. IBM ThinkPad t43 RAM Replacement: step 3, image 1 of 2 IBM ThinkPad t43 RAM Replacement: step 3, image 2 of 2
      • Place hands on the RAM and pull towards yourself
      • For replacement, follow these steps in reverse order
      • Make sure that when you put in the ram that the short side is on the right
      Ask FixBot
3 other people completed this guide.
Author
with
aLiX pIeRRe
899 Reputation
5 Guides authored
1 Guide Comment
There are two (2) SODIM slots on the T43 - this shows the easiest slot to access. There is a second SODIM slot underneath the keyboard. You will need to remove the palm rest and keyboard to access the second SODIM slot. This is the SODIM slot that comes populated with the 512MB SODIM.
Note you can add a 2GB SODIM in one slot with the 512MB SODIM in the other for a maximum of 2.5GB.
IrishMASMS - Reply Share
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 71
All Time: 2,087
