Up to 20% off select tools
IBM ThinkPad X41 Keyboard Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
4
Past 7 Days:
16
Past 30 Days:
108
All Time:
1,470
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 - 45 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will show you how to replace your entire keyboard for your IBM ThinkPad X41.
    1. IBM ThinkPad X41 Keyboard Replacement, Keyboard: step 1, image 1 of 3 IBM ThinkPad X41 Keyboard Replacement, Keyboard: step 1, image 2 of 3 IBM ThinkPad X41 Keyboard Replacement, Keyboard: step 1, image 3 of 3
      • Slide outward to unlock and lift battery up to remove.
      • Remove battery before keyboard to avoid damage to battery.
      Ask FixBot
    2. IBM ThinkPad X41 Keyboard Replacement: step 2, image 1 of 1
      • With a Phillips PH000 to remove all six 6 mm screws identified for the keyboard as shown.
      Ask FixBot
    3. IBM ThinkPad X41 Keyboard Replacement: step 3, image 1 of 3 IBM ThinkPad X41 Keyboard Replacement: step 3, image 2 of 3 IBM ThinkPad X41 Keyboard Replacement: step 3, image 3 of 3
      • Flip the laptop over once more returning it to its upright position and open laptop .
      Ask FixBot
    4. IBM ThinkPad X41 Keyboard Replacement: step 4, image 1 of 2 IBM ThinkPad X41 Keyboard Replacement: step 4, image 2 of 2
      • Using your left hand, place thumb on the upper part of the keyboard and place your other thumb on the bottom part of the keyboard.
      • Push firmly upward with both thumbs. This will detach keyboard from base.
      • Be cautious when lifting as there is an orange connection cable still attached to the bottom side.
      Ask FixBot
    5. IBM ThinkPad X41 Keyboard Replacement: step 5, image 1 of 2 IBM ThinkPad X41 Keyboard Replacement: step 5, image 2 of 2
      • Detach the connection to the motherboard by first sliding it towards you, then pulling upward away from your body.
      • This step's directions are based on the angle shown .
      Ask FixBot
    6. IBM ThinkPad X41 Keyboard Replacement: step 6, image 1 of 1
      • Lift the entire keyboard off the laptop.
      Ask FixBot
Author
with
Lisbeth Cisneros
131 Reputation
1 Guide authored
CSU Fullerton, Team 2-4, Bruce Fall 2016 Member of CSU Fullerton, Team 2-4, Bruce Fall 2016
CSUF-BRUCE-F16S2G4
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 16
Past 30 Days: 108
All Time: 1,470
