Up to 20% off select tools
IBM ThinkPad T43 Screen Replacement
Views: 2.5K
View statistics:
Past 24 Hours:
2
Past 7 Days:
12
Past 30 Days:
79
All Time:
2,489
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
Introduction
Go to step 1 ↓
This guide shows how to take out and replace the screen in this device.
    1. IBM ThinkPad T43 Screen Replacement, Screen: step 1, image 1 of 3 IBM ThinkPad T43 Screen Replacement, Screen: step 1, image 2 of 3 IBM ThinkPad T43 Screen Replacement, Screen: step 1, image 3 of 3
      • Locate the screws holding the screen cover in place.
      • There are 3 screws on the left side, 4 on the right, and 4 across the bottom of the screen.
      Ask FixBot
    2. IBM ThinkPad T43 Screen Replacement: step 2, image 1 of 3 IBM ThinkPad T43 Screen Replacement: step 2, image 2 of 3 IBM ThinkPad T43 Screen Replacement: step 2, image 3 of 3
      • Remove the covers by inserting plastic spudger in between the edge of the cover and laptop.
      • Remove screws by using the Phillips head #0
      • The covers are set in with an adhesive so they may pop off when removing them.
      Ask FixBot
    3. IBM ThinkPad T43 Screen Replacement: step 3, image 1 of 3 IBM ThinkPad T43 Screen Replacement: step 3, image 2 of 3 IBM ThinkPad T43 Screen Replacement: step 3, image 3 of 3
      • Insert the flat metal spudger into the edge of the screen cover and slowly pry open.
      • Slide the spudger along the edges and pry open to release the cover from the clips
      • While slide the spudger up the side of the cover, pinch the cover to help unhook the clips
      • Across the bottom of the screen there is an adhesive, so you will need to carefully pry of that part of the cover
      Ask FixBot
    4. IBM ThinkPad T43 Screen Replacement: step 4, image 1 of 1
      • Remove the two screws located near the bottom middle of the screen
      Ask FixBot
    5. IBM ThinkPad T43 Screen Replacement: step 5, image 1 of 3 IBM ThinkPad T43 Screen Replacement: step 5, image 2 of 3 IBM ThinkPad T43 Screen Replacement: step 5, image 3 of 3
      Tool used on this step:
      Buy
      • Flip over the green rectangular shaped board
      • Disconnect the screen from the rectangular board using your fingers or tweezers
      Ask FixBot
    6. IBM ThinkPad T43 Screen Replacement: step 6, image 1 of 1
      • Using "Flat metal spudger" lift up the screen from the bottom slowly until you see the ribbon cable
      • Detach the ribbon cable before lifting completely the screen
      • Now you be able to remove the screen
      • Because of how the ribbon cable is connected, it may detach when you lift the screen up
      Ask FixBot
    7. IBM ThinkPad T43 Screen Replacement: step 7, image 1 of 3 IBM ThinkPad T43 Screen Replacement: step 7, image 2 of 3 IBM ThinkPad T43 Screen Replacement: step 7, image 3 of 3
      • To replace the screen follow the next set of steps
      • Using your fingers or tweezers, pull out the light by placing them on the sides and lifting up
      • Insert the wide plug on the ribbon cable into the new screen and place back into the laptop.
      • Now if you follow these steps in reverse order, you will be able to finish replacing the screen
      Ask FixBot
Author
with
aLiX pIeRRe
899 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 79
All Time: 2,489
