IBM ThinkPad T42 Wi-Fi Card Replacement
    1. IBM ThinkPad T42 Wi-Fi Card Replacement, Bottom cover: step 1, image 1 of 1
      • Use a Phillips #0 screwdriver to remove the twenty screws on the underside of the T42.
      Ask FixBot
    2. IBM ThinkPad T42 Wi-Fi Card Replacement, Rear screws: step 2, image 1 of 1
      • Remove the four Phillips screws located on either side of the rear of the T42 (there are two on each end.)
      Ask FixBot
    1. IBM ThinkPad T42 Wi-Fi Card Replacement, Keyboard and Trackpad: step 3, image 1 of 1
      • Flip the laptop over and open the screen to access the keyboard and trackpad.
      • The keyboard and trackpad are connected to the motherboard. Before removing the keyboard and trackpad, disconnect both components from the motherboard, as shown in the following step.
      • The bezel and keyboard will be loose, be careful.
      Ask FixBot
    2. IBM ThinkPad T42 Wi-Fi Card Replacement: step 4, image 1 of 2 IBM ThinkPad T42 Wi-Fi Card Replacement: step 4, image 2 of 2
      • Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together.
      • Remember, both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
      Ask FixBot
    1. IBM ThinkPad T42 Wi-Fi Card Replacement, Wi-Fi Card: step 5, image 1 of 1
      • To remove Wi-Fi card, first disconnect both display wires on the top right.
      Ask FixBot
    2. IBM ThinkPad T42 Wi-Fi Card Replacement: step 6, image 1 of 1
      • Then slide both of the metal pieces holding it down outwards, and it will pop up.
      Ask FixBot
    3. IBM ThinkPad T42 Wi-Fi Card Replacement: step 7, image 1 of 1
      • Carefully pull it out.
      Ask FixBot
3 other people completed this guide.
Kevin Rehm
472 Reputation
4 Guides authored
Cal Poly, Team 29-76, Johann Spring 2010 Member of Cal Poly, Team 29-76, Johann Spring 2010
CPSU-JOHANN-S10S29G76
4 Members
180 Guides authored
2 Guide Comments
Get the HMM for the laptop! On a few of these, I have had to just pull out the internal wi-fi card, and use a USB wi-fi adapter.
Martin Campbell - Reply Share
The only screws that need to be removed are the ones that are numbered 1-4 on the bottom of the case. Best to remove the screws with #4 next to them, then remove the keyboard and then remove 1-3 and then the palm rest. Removing the ones on the rear is unnecessary.
John Casey - Reply Share
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 36
All Time: 14,619
