IBM ThinkPad T42 Mini-PCI Port Replacement
    1. IBM ThinkPad T42 Mini-PCI Port Replacement, Bottom cover: step 1, image 1 of 1
      • Use a Phillips #0 screwdriver to remove the twenty screws on the underside of the T42.
      Ask FixBot
    2. IBM ThinkPad T42 Mini-PCI Port Replacement, Rear screws: step 2, image 1 of 1
      • Remove the four Phillips screws located on either side of the rear of the T42 (there are two on each end.)
      Ask FixBot
    1. IBM ThinkPad T42 Mini-PCI Port Replacement, Keyboard and Trackpad: step 3, image 1 of 1
      • Flip the laptop over and open the screen to access the keyboard and trackpad.
      • The keyboard and trackpad are connected to the motherboard. Before removing the keyboard and trackpad, disconnect both components from the motherboard, as shown in the following step.
      • The bezel and keyboard will be loose, be careful.
      Ask FixBot
    2. IBM ThinkPad T42 Mini-PCI Port Replacement: step 4, image 1 of 2 IBM ThinkPad T42 Mini-PCI Port Replacement: step 4, image 2 of 2
      • Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together.
      • Remember, both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
      Ask FixBot
    1. IBM ThinkPad T42 Mini-PCI Port Replacement, Port Bracket: step 5, image 1 of 1
      • Remove the screw affixing the bracket down.
      Ask FixBot
    2. IBM ThinkPad T42 Mini-PCI Port Replacement, Bracket Removal: step 6, image 1 of 1
      • Lift the bracket up and out.
      Ask FixBot
    3. IBM ThinkPad T42 Mini-PCI Port Replacement, Port Removal: step 7, image 1 of 1
      • Carefully disconnect it from the motherboard and pull it out of the device.
      Ask FixBot
Gerald Watanabe
288 Reputation
7 Guides authored
Cal Poly, Team 29-76, Johann Spring 2010 Member of Cal Poly, Team 29-76, Johann Spring 2010
CPSU-JOHANN-S10S29G76
4 Members
180 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 30
All Time: 5,002
