IBM ThinkPad T42 Keyboard and Trackpad Replacement
Views: 11K
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
94
All Time:
10,953
Comments: 2
2 comments on steps.
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Missing Steps
Oops! This guide is currently missing one or more important steps.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. IBM ThinkPad T42 Keyboard and Trackpad Replacement, Bottom cover: step 1, image 1 of 1
      • Use a Phillips #0 screwdriver to remove the twenty screws on the underside of the T42.
      Ask FixBot
    2. IBM ThinkPad T42 Keyboard and Trackpad Replacement, Rear screws: step 2, image 1 of 1
      • Remove the four Phillips screws located on either side of the rear of the T42 (there are two on each end.)
      Ask FixBot
    1. IBM ThinkPad T42 Keyboard and Trackpad Replacement, Keyboard and Trackpad: step 3, image 1 of 1
      • Flip the laptop over and open the screen to access the keyboard and trackpad.
      • The keyboard and trackpad are connected to the motherboard. Before removing the keyboard and trackpad, disconnect both components from the motherboard, as shown in the following step.
      • The bezel and keyboard will be loose, be careful.
      Ask FixBot
    2. IBM ThinkPad T42 Keyboard and Trackpad Replacement: step 4, image 1 of 2 IBM ThinkPad T42 Keyboard and Trackpad Replacement: step 4, image 2 of 2
      • Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together.
      • Remember, both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
      Ask FixBot
3 other people completed this guide.
Austin Kidd
317 Reputation
3 Guides authored
Cal Poly, Team 29-76, Johann Spring 2010 Member of Cal Poly, Team 29-76, Johann Spring 2010
CPSU-JOHANN-S10S29G76
4 Members
180 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 94
All Time: 10,953
