Up to 20% off select tools
IBM ThinkPad T42 Fan Replacement
Views: 28K
View statistics:
Past 24 Hours:
7
Past 7 Days:
26
Past 30 Days:
122
All Time:
27,921
Comments: 4
2 comments on steps, 2 guide comments.
Go to guide comments
Completed: 8
8 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Missing Steps
Oops! This guide is currently missing one or more important steps.
Student In Progress
This guide is being worked on by hardworking students.
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Tools
  • Phillips #0 Screwdriver
    5
  • Spudger
    4.9
Introduction
Go to step 1 ↓
Use this guide to replace a fan for an IBM ThinkPad (Model T42). If your computer is making excessive noises, sounds louder than usual, or feels hot to the touch, the fan may need to be replaced. The fans' purpose is to pull cooler air into the computer to cool the hot circuitry. A failing fan can cause your laptop to sound louder because it is working harder than it normally needs to. Prior to using this guide, ensure nothing is blocking the fan or is in the way of the flow of the fan. A quick cleaning of debris or built-up dirt with a microfiber cloth may improve the functionality of the fan. If the fan is still dysfunctional, the next step would be to move forward with replacing the fan. Before beginning the process of replacing the fan make sure that your device is fully turned off and disconnected from any external power sources.
    1. IBM ThinkPad T42 Fan Replacement, Bottom cover: step 1, image 1 of 1
      • Use a Phillips #0 screwdriver to remove the twenty screws on the underside of the T42.
      Ask FixBot
    2. IBM ThinkPad T42 Fan Replacement, Rear screws: step 2, image 1 of 1
      • Remove the four Phillips screws located on either side of the rear of the T42 (there are two on each end.)
      Ask FixBot
    1. IBM ThinkPad T42 Fan Replacement, Keyboard and Trackpad: step 3, image 1 of 1
      • Flip the laptop over and open the screen to access the keyboard and trackpad.
      • The keyboard and trackpad are connected to the motherboard. Before removing the keyboard and trackpad, disconnect both components from the motherboard, as shown in the following step.
      • The bezel and keyboard will be loose, be careful.
      Ask FixBot
    2. IBM ThinkPad T42 Fan Replacement: step 4, image 1 of 2 IBM ThinkPad T42 Fan Replacement: step 4, image 2 of 2
      • Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together.
      • Remember, both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
      Ask FixBot
    1. IBM ThinkPad T42 Fan Replacement, Plastic Edge Cover: step 5, image 1 of 2 IBM ThinkPad T42 Fan Replacement, Plastic Edge Cover: step 5, image 2 of 2
      • Starting from the bottom right, carefully remove the bezel by pulling it up gently. If needed use a spudger or flathead screwdriver to help.
      Ask FixBot
    1. IBM ThinkPad T42 Fan Replacement, Lower Bracket: step 6, image 1 of 2 IBM ThinkPad T42 Fan Replacement, Lower Bracket: step 6, image 2 of 2
      • Grasp the metal bracket to remove it from the device.
      Ask FixBot
    2. IBM ThinkPad T42 Fan Replacement, Microphone cover: step 7, image 1 of 1
      • Remove the rubber cover from the microphone.
      Ask FixBot
    1. IBM ThinkPad T42 Fan Replacement, Fan Removal: step 8, image 1 of 2 IBM ThinkPad T42 Fan Replacement, Fan Removal: step 8, image 2 of 2
      • Using the Phillips #0 screwdriver, remove the three screws on the copper heatsink.
      • Separate the copper heatsink by pulling it upwards, in order to unplug the connector from the motherboard.
      • Due to the nature of old thermal paste, it might take some force to remove the heatsink.
      Ask FixBot
8 other people completed this guide.
Author
with
Kevin Rehm
472 Reputation
4 Guides authored
Cal Poly, Team 29-76, Johann Spring 2010 Member of Cal Poly, Team 29-76, Johann Spring 2010
CPSU-JOHANN-S10S29G76
4 Members
180 Guides authored
2 Guide Comments
How about you just down the freely available Hardware Maintenance Manual (HMM) for the laptop. They are downloadable in PDF format, and very well done.
Martin Campbell - Reply Share
It doesnt take this much, if you remove the palm rest and keyboard you can get it at an angle it slides straight out.
Tobyn Genn - Reply Share
Past 24 Hours: 7
Past 7 Days: 26
Past 30 Days: 122
All Time: 27,921
