Up to 20% off select tools
IBM ThinkPad T42 Display Replacement
Views: 14K
View statistics:
Past 24 Hours:
6
Past 7 Days:
22
Past 30 Days:
113
All Time:
14,401
Comments: 5
3 comments on steps, 2 guide comments.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 25 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Missing Steps
Oops! This guide is currently missing one or more important steps.
Student In Progress
This guide is being worked on by hardworking students.
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Tools
Introduction
Go to step 1 ↓
Removal/repair of the display
    1. IBM ThinkPad T42 Display Replacement, Bottom cover: step 1, image 1 of 1
      • Use a Phillips #0 screwdriver to remove the twenty screws on the underside of the T42.
      Ask FixBot
    2. IBM ThinkPad T42 Display Replacement, Rear screws: step 2, image 1 of 1
      • Remove the four Phillips screws located on either side of the rear of the T42 (there are two on each end.)
      Ask FixBot
    1. IBM ThinkPad T42 Display Replacement, Keyboard and Trackpad: step 3, image 1 of 1
      • Flip the laptop over and open the screen to access the keyboard and trackpad.
      • The keyboard and trackpad are connected to the motherboard. Before removing the keyboard and trackpad, disconnect both components from the motherboard, as shown in the following step.
      • The bezel and keyboard will be loose, be careful.
      Ask FixBot
    2. IBM ThinkPad T42 Display Replacement: step 4, image 1 of 2 IBM ThinkPad T42 Display Replacement: step 4, image 2 of 2
      • Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together.
      • Remember, both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
      Ask FixBot
    1. IBM ThinkPad T42 Display Replacement, Bezel Removal: step 5, image 1 of 2 IBM ThinkPad T42 Display Replacement, Bezel Removal: step 5, image 2 of 2
      • Remove the plastic bezel along the edges, you may need to pry the areas circled with a spudger to remove the bezel.
      Ask FixBot
    2. IBM ThinkPad T42 Display Replacement, Display Screws: step 6, image 1 of 1
      • Unscrew the screws holding down the display.
      • Along with the one pictured in red, there is another one along the top right edge.
      Ask FixBot
    3. IBM ThinkPad T42 Display Replacement, Display and Ribbon Cable Removal: step 7, image 1 of 1
      • Carefully unplug the display ribbon on the motherboard, then carefully lift the display free from the device.
      Ask FixBot
6 other people completed this guide.
Author
with
Austin Kidd
335 Reputation
3 Guides authored
Cal Poly, Team 29-76, Johann Spring 2010 Member of Cal Poly, Team 29-76, Johann Spring 2010
CPSU-JOHANN-S10S29G76
4 Members
180 Guides authored
2 Guide Comments
@Seth
Just use the pic numbering left to right each of the 4 rows.
Start at the top and remove in sequence, placing each on a strip of heavy tape to keep the screws in sequence.
Place a second strip on top when finished to secure the sequence until it's time to re-assemble.
Michael G - Reply Share
Very poor & sketchy guide! NO mention at all of how to handle the other wires involved in disconnecting the screen (lid) from the laptop base, eg: the wireless antenna connections and instructions like: "Unscrew the screws holding it down" are far too vague! holding WHAT down ffs!!!!
wbcam - Reply Share
Past 24 Hours: 6
Past 7 Days: 22
Past 30 Days: 113
All Time: 14,401
