Up to 20% off select tools
IBM ThinkPad T42 Battery Replacement
Views: 6.9K
View statistics:
Past 24 Hours:
2
Past 7 Days:
20
Past 30 Days:
109
All Time:
6,906
Comments: 0
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
Changing the battery is easy -- you don't need a any tools.
    1. IBM ThinkPad T42 Battery Replacement, Battery Clips: step 1, image 1 of 1
      • Flip the laptop over so the underside is facing you, then, release the 2 clips holding the battery on.
      • Make sure the laptop is off when you do this, sudden power outages can cause data corruption.
      Ask FixBot
    2. IBM ThinkPad T42 Battery Replacement, Removing the Battery: step 2, image 1 of 1
      • Carefully grab the battery, then pull it straight out, not at an angle.
      Ask FixBot
6 other people completed this guide.
Author
with
Kevin Rehm
472 Reputation
4 Guides authored
Cal Poly, Team 29-76, Johann Spring 2010 Member of Cal Poly, Team 29-76, Johann Spring 2010
CPSU-JOHANN-S10S29G76
4 Members
180 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 109
All Time: 6,906
