Up to 20% off select tools
IBM ThinkPad T41 Screen Replacement
Views: 20K
View statistics:
Past 24 Hours:
4
Past 7 Days:
26
Past 30 Days:
103
All Time:
19,535
Comments: 2
2 comments on steps.
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 - 25 minutes
Difficulty: Moderate
Tools
  • Phillips #1 Screwdriver
    5
  • Spudger
    4.9
Introduction
Go to step 1 ↓
This repair guide will aid you in taking apart your IBM ThinkPad T41 laptop to reach and replace its screen.
    1. IBM ThinkPad T41 Screen Replacement, Keyboard: step 1, image 1 of 1
      • Close the screen and turn the closed laptop over.
      • Remove all 17 screws on the bottom of the computer.
      • The multiple colors (turquoise, red, blue, orange, yellow, and purple) are for organizational purposes, indicating different screws.
      • The yellow marker at the rear denotes the UltraBay device retaining screw. This screw is optional as the UltraBay mechanism will hold the drive or battery in place anyway. The yellow marker at the front denotes the hard disk caddy retaining screw.
      Ask FixBot
    2. IBM ThinkPad T41 Screen Replacement: step 2, image 1 of 1
      • Remove the extra RAM cover, by lifting where the screw was and pulling out.
      Ask FixBot
    3. IBM ThinkPad T41 Screen Replacement: step 3, image 1 of 1
      • Turn the laptop right side up and open the screen.
      • Lift the keyboard, using a spudger at the seam between the keyboard and trackpad.
      • Careful of the ribbon cable underneath, which may tear if the keyboard is lifted too vigorously.
      Ask FixBot
    4. IBM ThinkPad T41 Screen Replacement: step 4, image 1 of 1
      • Unplug the keyboard’s ribbon cable, by lifting up the edges of the plug.
      • Remove the keyboard.
      Ask FixBot
    1. IBM ThinkPad T41 Screen Replacement, Trackpad: step 5, image 1 of 1
      • Close the laptop and turn it over.
      • Remove the five plastic stickers covering the screws on the front edge of the case.
      • In order to reuse the stickers, remove them carefully.
      Ask FixBot
    2. IBM ThinkPad T41 Screen Replacement: step 6, image 1 of 1
      • Unscrew the five screws that were hidden by the stickers.
      Ask FixBot
    3. IBM ThinkPad T41 Screen Replacement: step 7, image 1 of 1
      • Turn the computer right side up and open the screen.
      • Lift the trackpad assembly by placing hands on both edges and then pull towards you till it is free of the case.
      • Be careful of the ribbon cable underneath. It may tear if the trackpad is pulled too vigorously.
      Ask FixBot
    4. IBM ThinkPad T41 Screen Replacement: step 8, image 1 of 1
      • Unplug the trackpad’s ribbon cable by pulling on the white plastic tab.
      Ask FixBot
    1. IBM ThinkPad T41 Screen Replacement, Wireless Network Card: step 9, image 1 of 1
      • Pull off the one black and one white coaxial cables by lifting the tabs labeled main and aux (for auxiliary).
      Ask FixBot
    2. IBM ThinkPad T41 Screen Replacement: step 10, image 1 of 1
      • Push apart the retaining clips.
      • Note: The card should pop up a little bit.
      Ask FixBot
    3. IBM ThinkPad T41 Screen Replacement: step 11, image 1 of 1
      • Pull the wireless network card out.
      Ask FixBot
    1. IBM ThinkPad T41 Screen Replacement, Screen: step 12, image 1 of 1
      • Close the computer screen.
      • Remove the four screws on the back of the laptop, near the right and left hinges.
      Ask FixBot
    2. IBM ThinkPad T41 Screen Replacement: step 13, image 1 of 1
      • Open the laptop screen.
      • Remove the single screw that secures the left hinge to top of the computer.
      Ask FixBot
    3. IBM ThinkPad T41 Screen Replacement: step 14, image 1 of 1
      • Remove a single screw from the metal plate that secures the display cable.
      Ask FixBot
    4. IBM ThinkPad T41 Screen Replacement: step 15, image 1 of 1
      • Pull the metal plate away from the display cable.
      Ask FixBot
    5. IBM ThinkPad T41 Screen Replacement: step 16, image 1 of 1
      • Disconnect the display cable.
      Ask FixBot
    6. IBM ThinkPad T41 Screen Replacement: step 17, image 1 of 1
      • Carefully pull up the long antenna cables that were attached to the wireless network card.
      Ask FixBot
    7. IBM ThinkPad T41 Screen Replacement: step 18, image 1 of 1
      • Lift out the screen.
      Ask FixBot
5 other people completed this guide.
Author
with
Marissa Blustein
543 Reputation
12 Guides authored
Cal Poly, Team 7-8, Maness Spring 2010 Member of Cal Poly, Team 7-8, Maness Spring 2010
CPSU-MANESS-S10S7G8
4 Members
156 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 26
Past 30 Days: 103
All Time: 19,535
