Up to 20% off select tools
IBM ThinkPad T41 RAM Replacement
Views: 8.6K
View statistics:
Past 24 Hours:
5
Past 7 Days:
24
Past 30 Days:
113
All Time:
8,596
Comments: 3
2 comments on steps, 1 guide comment.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Moderate
Tools
  • Phillips #1 Screwdriver
    5
  • Spudger
    4.9
Introduction
Go to step 1 ↓
This simple repair guide will aid you in taking apart your IBM ThinkPad T41 laptop to reach and replace its RAM.
    1. IBM ThinkPad T41 RAM Replacement, Keyboard: step 1, image 1 of 1
      • Close the screen and turn the closed laptop over.
      • Remove all 17 screws on the bottom of the computer.
      • The multiple colors (turquoise, red, blue, orange, yellow, and purple) are for organizational purposes, indicating different screws.
      • The yellow marker at the rear denotes the UltraBay device retaining screw. This screw is optional as the UltraBay mechanism will hold the drive or battery in place anyway. The yellow marker at the front denotes the hard disk caddy retaining screw.
      Ask FixBot
    2. IBM ThinkPad T41 RAM Replacement: step 2, image 1 of 1
      • Remove the extra RAM cover, by lifting where the screw was and pulling out.
      Ask FixBot
    3. IBM ThinkPad T41 RAM Replacement: step 3, image 1 of 1
      • Turn the laptop right side up and open the screen.
      • Lift the keyboard, using a spudger at the seam between the keyboard and trackpad.
      • Careful of the ribbon cable underneath, which may tear if the keyboard is lifted too vigorously.
      Ask FixBot
    4. IBM ThinkPad T41 RAM Replacement: step 4, image 1 of 1
      • Unplug the keyboard’s ribbon cable, by lifting up the edges of the plug.
      • Remove the keyboard.
      Ask FixBot
    1. IBM ThinkPad T41 RAM Replacement, RAM: step 5, image 1 of 1
      • Push apart the retaining clips on the RAM.
      • Note: The RAM should pop up a little bit.
      Ask FixBot
    2. IBM ThinkPad T41 RAM Replacement: step 6, image 1 of 1
      • Lift out the RAM chip.
      Ask FixBot
3 other people completed this guide.
Author
with
Marissa Blustein
543 Reputation
12 Guides authored
Cal Poly, Team 7-8, Maness Spring 2010 Member of Cal Poly, Team 7-8, Maness Spring 2010
CPSU-MANESS-S10S7G8
4 Members
156 Guides authored
1 Guide Comment
You only need to take out 4 screws on the bottom of the laptop that have a picture of a keyboard beside them to remove the keyboard. I don’t know why the tutorial says to take out all the screws. Other than that, great article.
Gary Thurman - Reply Share
Past 24 Hours: 5
Past 7 Days: 24
Past 30 Days: 113
All Time: 8,596
