IBM ThinkPad T41 Motherboard Replacement
    1. IBM ThinkPad T41 Motherboard Replacement, Keyboard: step 1, image 1 of 1
      • Close the screen and turn the closed laptop over.
      • Remove all 17 screws on the bottom of the computer.
      • The multiple colors (turquoise, red, blue, orange, yellow, and purple) are for organizational purposes, indicating different screws.
      • The yellow marker at the rear denotes the UltraBay device retaining screw. This screw is optional as the UltraBay mechanism will hold the drive or battery in place anyway. The yellow marker at the front denotes the hard disk caddy retaining screw.
      Ask FixBot
    2. IBM ThinkPad T41 Motherboard Replacement: step 2, image 1 of 1
      • Remove the extra RAM cover, by lifting where the screw was and pulling out.
      Ask FixBot
    3. IBM ThinkPad T41 Motherboard Replacement: step 3, image 1 of 1
      • Turn the laptop right side up and open the screen.
      • Lift the keyboard, using a spudger at the seam between the keyboard and trackpad.
      • Careful of the ribbon cable underneath, which may tear if the keyboard is lifted too vigorously.
      Ask FixBot
    4. IBM ThinkPad T41 Motherboard Replacement: step 4, image 1 of 1
      • Unplug the keyboard’s ribbon cable, by lifting up the edges of the plug.
      • Remove the keyboard.
      Ask FixBot
    1. IBM ThinkPad T41 Motherboard Replacement, Trackpad: step 5, image 1 of 1
      • Close the laptop and turn it over.
      • Remove the five plastic stickers covering the screws on the front edge of the case.
      • In order to reuse the stickers, remove them carefully.
      Ask FixBot
    2. IBM ThinkPad T41 Motherboard Replacement: step 6, image 1 of 1
      • Unscrew the five screws that were hidden by the stickers.
      Ask FixBot
    3. IBM ThinkPad T41 Motherboard Replacement: step 7, image 1 of 1
      • Turn the computer right side up and open the screen.
      • Lift the trackpad assembly by placing hands on both edges and then pull towards you till it is free of the case.
      • Be careful of the ribbon cable underneath. It may tear if the trackpad is pulled too vigorously.
      Ask FixBot
    4. IBM ThinkPad T41 Motherboard Replacement: step 8, image 1 of 1
      • Unplug the trackpad’s ribbon cable by pulling on the white plastic tab.
      Ask FixBot
    1. IBM ThinkPad T41 Motherboard Replacement, RAM: step 9, image 1 of 1
      • Push apart the retaining clips on the RAM.
      • Note: The RAM should pop up a little bit.
      Ask FixBot
    2. IBM ThinkPad T41 Motherboard Replacement: step 10, image 1 of 1
      • Lift out the RAM chip.
      Ask FixBot
    1. IBM ThinkPad T41 Motherboard Replacement, Wireless Network Card: step 11, image 1 of 1
      • Pull off the one black and one white coaxial cables by lifting the tabs labeled main and aux (for auxiliary).
      Ask FixBot
    2. IBM ThinkPad T41 Motherboard Replacement: step 12, image 1 of 1
      • Push apart the retaining clips.
      • Note: The card should pop up a little bit.
      Ask FixBot
    3. IBM ThinkPad T41 Motherboard Replacement: step 13, image 1 of 1
      • Pull the wireless network card out.
      Ask FixBot
    1. IBM ThinkPad T41 Motherboard Replacement, CMOS Battery: step 14, image 1 of 1
      • Lift the yellow plastic-covered battery up.
      Ask FixBot
    2. IBM ThinkPad T41 Motherboard Replacement: step 15, image 1 of 1
      • Unplug the battery connector.
      Ask FixBot
    1. IBM ThinkPad T41 Motherboard Replacement, Speakers: step 16, image 1 of 1
      • Lift the speakers out by starting with the left end and then unsnake the wires.
      Ask FixBot
    2. IBM ThinkPad T41 Motherboard Replacement: step 17, image 1 of 1
      • Unplug the wires from the motherboard.
      Ask FixBot
    1. IBM ThinkPad T41 Motherboard Replacement, Expansion Slot: step 18, image 1 of 1
      • Remove the screw on the left hand side of the case, above the expansion slot.
      Ask FixBot
    2. IBM ThinkPad T41 Motherboard Replacement: step 19, image 1 of 2 IBM ThinkPad T41 Motherboard Replacement: step 19, image 2 of 2
      • Lift the black plastic border by lifting on either side.
      • Once the sides are up, pull the border towards you and away from the screen.
      • When lifting up, there are two pairs of plastic clips hooking into the fan grill. If you pull hard enough the border will come away, but it's better to push the clips with the spudger.
      Ask FixBot
    3. IBM ThinkPad T41 Motherboard Replacement: step 20, image 1 of 1
      • Pull the sheet metal cover away from slot.
      Ask FixBot
    4. IBM ThinkPad T41 Motherboard Replacement: step 21, image 1 of 1
      • Lift out the expansion slot by starting at the entrance hole and pulling upward.
      • Note: Try wiggling the slot from side to side until it comes out all the way.
      Ask FixBot
    1. IBM ThinkPad T41 Motherboard Replacement, Modem: step 22, image 1 of 1
      • Remove the three screws holding down the modem in the upper left corner of the laptop.
      Ask FixBot
    2. IBM ThinkPad T41 Motherboard Replacement: step 23, image 1 of 1
      • Lift the modem up, unplugging it from the motherboard as you lift.
      Ask FixBot
    3. IBM ThinkPad T41 Motherboard Replacement: step 24, image 1 of 2 IBM ThinkPad T41 Motherboard Replacement: step 24, image 2 of 2
      • Pull out the wire that connects the modem to the screen.
      • Unplug the other cable that attaches the modem to the motherboard
      Ask FixBot
    1. IBM ThinkPad T41 Motherboard Replacement, Screen: step 25, image 1 of 1
      • Close the computer screen.
      • Remove the four screws on the back of the laptop, near the right and left hinges.
      Ask FixBot
    2. IBM ThinkPad T41 Motherboard Replacement: step 26, image 1 of 1
      • Open the laptop screen.
      • Remove the single screw that secures the left hinge to top of the computer.
      Ask FixBot
    3. IBM ThinkPad T41 Motherboard Replacement: step 27, image 1 of 1
      • Remove a single screw from the metal plate that secures the display cable.
      Ask FixBot
    4. IBM ThinkPad T41 Motherboard Replacement: step 28, image 1 of 1
      • Pull the metal plate away from the display cable.
      Ask FixBot
    5. IBM ThinkPad T41 Motherboard Replacement: step 29, image 1 of 1
      • Disconnect the display cable.
      Ask FixBot
    6. IBM ThinkPad T41 Motherboard Replacement: step 30, image 1 of 1
      • Carefully pull up the long antenna cables that were attached to the wireless network card.
      Ask FixBot
    7. IBM ThinkPad T41 Motherboard Replacement: step 31, image 1 of 1
      • Lift out the screen.
      Ask FixBot
    1. IBM ThinkPad T41 Motherboard Replacement, Fan: step 32, image 1 of 1
      • Unsnake the black cable from the black plastic frame.
      Ask FixBot
    2. IBM ThinkPad T41 Motherboard Replacement: step 33, image 1 of 1
      • Remove the sheet metal piece, which was underneath the modem.
      Ask FixBot
    3. IBM ThinkPad T41 Motherboard Replacement: step 34, image 1 of 1
      • Remove the rubber microphone cover in the upper left hand corner by lifting up the gray metal frame.
      Ask FixBot
    4. IBM ThinkPad T41 Motherboard Replacement: step 35, image 1 of 1
      • Lift away the gray metal frame.
      Ask FixBot
    5. IBM ThinkPad T41 Motherboard Replacement: step 36, image 1 of 1
      • Remove three screws near the edge of the computer, holding the optical bay and HDD covers.
      • Remove three other screws on the other side of the covers.
      • You should have six screws in total, three of one size and three of another size.
      Ask FixBot
    6. IBM ThinkPad T41 Motherboard Replacement: step 37, image 1 of 1
      • Lift out the optical bay and HDD covers.
      Ask FixBot
    7. IBM ThinkPad T41 Motherboard Replacement: step 38, image 1 of 1
      • Lift out the black plastic frame.
      Ask FixBot
    8. IBM ThinkPad T41 Motherboard Replacement: step 39, image 1 of 1
      • Unplug the fan from the motherboard.
      Ask FixBot
    9. IBM ThinkPad T41 Motherboard Replacement: step 40, image 1 of 1
      • Remove the three screws on the fan.
      Ask FixBot
    10. IBM ThinkPad T41 Motherboard Replacement: step 41, image 1 of 1
      • Lift the fan out.
      Ask FixBot
    1. IBM ThinkPad T41 Motherboard Replacement, CPU: step 42, image 1 of 1
      • Turn the CPU retaining screw 90 degrees counterclockwise.
      • Carefully pull the CPU out of its socket.
      Ask FixBot
    1. IBM ThinkPad T41 Motherboard Replacement, Motherboard: step 43, image 1 of 1
      • Remove the two screws in the upper right corner that secure the gray metal frame.
      Ask FixBot
    2. IBM ThinkPad T41 Motherboard Replacement: step 44, image 1 of 1
      • Unplug the small ribbon cable attached to the motherboard.
      Ask FixBot
    3. IBM ThinkPad T41 Motherboard Replacement: step 45, image 1 of 1
      • Remove the single screw located next to the USB slots.
      Ask FixBot
    4. IBM ThinkPad T41 Motherboard Replacement: step 46, image 1 of 1
      • Rotate the device so that the front faces you.
      • Lift the entire motherboard assembly out of the case.
      Ask FixBot
    5. IBM ThinkPad T41 Motherboard Replacement: step 47, image 1 of 1
      • Disconnect the power connector from the motherboard.
      Ask FixBot
    6. IBM ThinkPad T41 Motherboard Replacement: step 48, image 1 of 1
      • Using a nut driver or a pair of thin nose pliers, remove the two stand off screws next to the pink parallel port on the back of the computer.
      Ask FixBot
    7. IBM ThinkPad T41 Motherboard Replacement: step 49, image 1 of 1
      • Lift up the outer end of the grey metal frame.
      • Carefully rotate the frame clockwise to release it from the motherboard.
      Ask FixBot
20 other people completed this guide.
Marissa Blustein
543 Reputation
12 Guides authored
Cal Poly, Team 7-8, Maness Spring 2010 Member of Cal Poly, Team 7-8, Maness Spring 2010
CPSU-MANESS-S10S7G8
4 Members
156 Guides authored
6 Guide Comments
Hello,
Thanks for this !
When assembling again, I noticed that at the contact between the micro-processor and the cooler the thermal paste there was a very small amount of thermal paste.
I had none to add, therefore I reassembled as is.
After starting the machine again I note that the cooling fan never stops.
I suggest that at reassembling should thermal paste added.
Philippe - Reply Share
ibm thinkpad t42 laptop driver are not download please sir my laptop motherboard information send in my email id . how can download driver download for ibm laptop
Himanshu Kumar - Reply Share
Excellent tutorial. Thank you.
genese_cranford - Reply Share
thanks alot!
Geburtswehe - Reply Share
It’s tempting to try, but I’d feel much braver with a reassembly tutorial!
Christine Segatti - Reply Share
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 58
All Time: 51,335
