Up to 20% off select tools
IBM ThinkPad T41 Modem Replacement
Views: 5K
View statistics:
Past 24 Hours:
3
Past 7 Days:
25
Past 30 Days:
85
All Time:
4,996
Comments: 2
2 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 20 minutes
Difficulty: Moderate
Tools
  • Phillips #1 Screwdriver
    5
  • Spudger
    4.9
Introduction
Go to step 1 ↓
This repair guide will aid you in taking apart your IBM ThinkPad T41 laptop to reach and replace its modem.
    1. IBM ThinkPad T41 Modem Replacement, Keyboard: step 1, image 1 of 1
      • Close the screen and turn the closed laptop over.
      • Remove all 17 screws on the bottom of the computer.
      • The multiple colors (turquoise, red, blue, orange, yellow, and purple) are for organizational purposes, indicating different screws.
      • The yellow marker at the rear denotes the UltraBay device retaining screw. This screw is optional as the UltraBay mechanism will hold the drive or battery in place anyway. The yellow marker at the front denotes the hard disk caddy retaining screw.
      Ask FixBot
    2. IBM ThinkPad T41 Modem Replacement: step 2, image 1 of 1
      • Remove the extra RAM cover, by lifting where the screw was and pulling out.
      Ask FixBot
    3. IBM ThinkPad T41 Modem Replacement: step 3, image 1 of 1
      • Turn the laptop right side up and open the screen.
      • Lift the keyboard, using a spudger at the seam between the keyboard and trackpad.
      • Careful of the ribbon cable underneath, which may tear if the keyboard is lifted too vigorously.
      Ask FixBot
    4. IBM ThinkPad T41 Modem Replacement: step 4, image 1 of 1
      • Unplug the keyboard’s ribbon cable, by lifting up the edges of the plug.
      • Remove the keyboard.
      Ask FixBot
    1. IBM ThinkPad T41 Modem Replacement, Modem: step 5, image 1 of 1
      • Remove the three screws holding down the modem in the upper left corner of the laptop.
      Ask FixBot
    2. IBM ThinkPad T41 Modem Replacement: step 6, image 1 of 1
      • Lift the modem up, unplugging it from the motherboard as you lift.
      Ask FixBot
    3. IBM ThinkPad T41 Modem Replacement: step 7, image 1 of 2 IBM ThinkPad T41 Modem Replacement: step 7, image 2 of 2
      • Pull out the wire that connects the modem to the screen.
      • Unplug the other cable that attaches the modem to the motherboard
      Ask FixBot
Author
with
Marissa Blustein
543 Reputation
12 Guides authored
Cal Poly, Team 7-8, Maness Spring 2010 Member of Cal Poly, Team 7-8, Maness Spring 2010
CPSU-MANESS-S10S7G8
4 Members
156 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 25
Past 30 Days: 85
All Time: 4,996
