Up to 20% off select tools
IBM ThinkPad T41 Keyboard Replacement
Views: 9.5K
View statistics:
Past 24 Hours:
4
Past 7 Days:
25
Past 30 Days:
104
All Time:
9,510
Comments: 2
2 comments on steps.
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 6
6 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Moderate
Tools
  • Phillips #1 Screwdriver
    5
  • Spudger
    4.9
Introduction
Go to step 1 ↓
This simple repair guide will aid you in taking apart your IBM ThinkPad T41 laptop to reach and replace its keyboard.
    1. IBM ThinkPad T41 Keyboard Replacement, Keyboard: step 1, image 1 of 1
      • Close the screen and turn the closed laptop over.
      • Remove all 17 screws on the bottom of the computer.
      • The multiple colors (turquoise, red, blue, orange, yellow, and purple) are for organizational purposes, indicating different screws.
      • The yellow marker at the rear denotes the UltraBay device retaining screw. This screw is optional as the UltraBay mechanism will hold the drive or battery in place anyway. The yellow marker at the front denotes the hard disk caddy retaining screw.
      Ask FixBot
    2. IBM ThinkPad T41 Keyboard Replacement: step 2, image 1 of 1
      • Remove the extra RAM cover, by lifting where the screw was and pulling out.
      Ask FixBot
    3. IBM ThinkPad T41 Keyboard Replacement: step 3, image 1 of 1
      • Turn the laptop right side up and open the screen.
      • Lift the keyboard, using a spudger at the seam between the keyboard and trackpad.
      • Careful of the ribbon cable underneath, which may tear if the keyboard is lifted too vigorously.
      Ask FixBot
    4. IBM ThinkPad T41 Keyboard Replacement: step 4, image 1 of 1
      • Unplug the keyboard’s ribbon cable, by lifting up the edges of the plug.
      • Remove the keyboard.
      Ask FixBot
4 other people completed this guide.
Author
with
Marissa Blustein
543 Reputation
12 Guides authored
Cal Poly, Team 7-8, Maness Spring 2010 Member of Cal Poly, Team 7-8, Maness Spring 2010
CPSU-MANESS-S10S7G8
4 Members
156 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 25
Past 30 Days: 104
All Time: 9,510
