IBM ThinkPad T41 Expansion Slot Replacement
    1. IBM ThinkPad T41 Expansion Slot Replacement, Keyboard: step 1, image 1 of 1
      • Close the screen and turn the closed laptop over.
      • Remove all 17 screws on the bottom of the computer.
      • The multiple colors (turquoise, red, blue, orange, yellow, and purple) are for organizational purposes, indicating different screws.
      • The yellow marker at the rear denotes the UltraBay device retaining screw. This screw is optional as the UltraBay mechanism will hold the drive or battery in place anyway. The yellow marker at the front denotes the hard disk caddy retaining screw.
      Ask FixBot
    2. IBM ThinkPad T41 Expansion Slot Replacement: step 2, image 1 of 1
      • Remove the extra RAM cover, by lifting where the screw was and pulling out.
      Ask FixBot
    3. IBM ThinkPad T41 Expansion Slot Replacement: step 3, image 1 of 1
      • Turn the laptop right side up and open the screen.
      • Lift the keyboard, using a spudger at the seam between the keyboard and trackpad.
      • Careful of the ribbon cable underneath, which may tear if the keyboard is lifted too vigorously.
      Ask FixBot
    4. IBM ThinkPad T41 Expansion Slot Replacement: step 4, image 1 of 1
      • Unplug the keyboard’s ribbon cable, by lifting up the edges of the plug.
      • Remove the keyboard.
      Ask FixBot
    1. IBM ThinkPad T41 Expansion Slot Replacement, Trackpad: step 5, image 1 of 1
      • Close the laptop and turn it over.
      • Remove the five plastic stickers covering the screws on the front edge of the case.
      • In order to reuse the stickers, remove them carefully.
      Ask FixBot
    2. IBM ThinkPad T41 Expansion Slot Replacement: step 6, image 1 of 1
      • Unscrew the five screws that were hidden by the stickers.
      Ask FixBot
    3. IBM ThinkPad T41 Expansion Slot Replacement: step 7, image 1 of 1
      • Turn the computer right side up and open the screen.
      • Lift the trackpad assembly by placing hands on both edges and then pull towards you till it is free of the case.
      • Be careful of the ribbon cable underneath. It may tear if the trackpad is pulled too vigorously.
      Ask FixBot
    4. IBM ThinkPad T41 Expansion Slot Replacement: step 8, image 1 of 1
      • Unplug the trackpad’s ribbon cable by pulling on the white plastic tab.
      Ask FixBot
    1. IBM ThinkPad T41 Expansion Slot Replacement, Speakers: step 9, image 1 of 1
      • Lift the speakers out by starting with the left end and then unsnake the wires.
      Ask FixBot
    2. IBM ThinkPad T41 Expansion Slot Replacement: step 10, image 1 of 1
      • Unplug the wires from the motherboard.
      Ask FixBot
    1. IBM ThinkPad T41 Expansion Slot Replacement, Expansion Slot: step 11, image 1 of 1
      • Remove the screw on the left hand side of the case, above the expansion slot.
      Ask FixBot
    2. IBM ThinkPad T41 Expansion Slot Replacement: step 12, image 1 of 2 IBM ThinkPad T41 Expansion Slot Replacement: step 12, image 2 of 2
      • Lift the black plastic border by lifting on either side.
      • Once the sides are up, pull the border towards you and away from the screen.
      • When lifting up, there are two pairs of plastic clips hooking into the fan grill. If you pull hard enough the border will come away, but it's better to push the clips with the spudger.
      Ask FixBot
    3. IBM ThinkPad T41 Expansion Slot Replacement: step 13, image 1 of 1
      • Pull the sheet metal cover away from slot.
      Ask FixBot
    4. IBM ThinkPad T41 Expansion Slot Replacement: step 14, image 1 of 1
      • Lift out the expansion slot by starting at the entrance hole and pulling upward.
      • Note: Try wiggling the slot from side to side until it comes out all the way.
      Ask FixBot
Marissa Blustein
543 Reputation
12 Guides authored
Cal Poly, Team 7-8, Maness Spring 2010 Member of Cal Poly, Team 7-8, Maness Spring 2010
CPSU-MANESS-S10S7G8
4 Members
156 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 30
All Time: 3,836
