Up to 20% off select tools
IBM ThinkPad T30 Processor Replacement
Views: 6.4K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
108
All Time:
6,356
Comments: 1
1 comment on steps.
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes - 1 hour
Difficulty: Moderate
Missing Steps
Oops! This guide is currently missing one or more important steps.
Tools
Introduction
Go to step 1 ↓
The IBM ThinkPad T30 is a reliable laptop, but like many older systems, its processor (CPU) can become outdated or fail over time. The processor is responsible for executing instructions and running applications, so issues such as overheating, slow performance, or system instability can often be traced back to this component.
If troubleshooting steps such as cleaning the cooling system or reapplying thermal paste have not resolved these issues, replacing the processor may be necessary. This repair can help improve performance and restore the system to stable working condition.
In this guide, you will learn how to safely remove and replace the processor in the ThinkPad T30. This is a more advanced repair that requires working with internal components and should be attempted by users with some repair experience.
Before beginning, ensure the laptop is completely powered off, unplugged, and the battery is removed. It is also recommended to work in a static-free environment to avoid damaging sensitive components. During disassembly, you will need to carefully remove the cooling assembly, so be cautious of thermal paste and ensure it is properly cleaned and reapplied during reinstallation.
Avoid touching the processor contacts directly, and handle all components with care to prevent damage. Take your time during each step and keep track of screws and parts to ensure proper reassembly.
    1. IBM ThinkPad T30 Processor Replacement, Battery: step 1, image 1 of 3 IBM ThinkPad T30 Processor Replacement, Battery: step 1, image 2 of 3 IBM ThinkPad T30 Processor Replacement, Battery: step 1, image 3 of 3
      • Make sure the ThinkPad is off and the power supply is unplugged.
      • Flip the ThinkPad upside down with the bottom facing you.
      • Slide the latch to the right into the unlock position.
      • While holding the latch in the unlock position, lift the battery out with your other hand.
      Ask FixBot
    1. IBM ThinkPad T30 Processor Replacement, Keyboard: step 2, image 1 of 2 IBM ThinkPad T30 Processor Replacement, Keyboard: step 2, image 2 of 2
      • Begin by removing the two black 16 mm Phillips #0 screws. The screws can be identified by the two notches next to each screw. One (marked in red) is near the battery lock and the other (not pictured) is next to the Wi-Fi cover.
      • Push up the bottom of the keyboard by poking your finger through the hole to the right of the yellow bios battery. You will feel slight resistance.
      • Be sure to not lift the keyboard too far. It is still attached to the computer with a ribbon connector.
      Ask FixBot
    2. IBM ThinkPad T30 Processor Replacement: step 3, image 1 of 3 IBM ThinkPad T30 Processor Replacement: step 3, image 2 of 3 IBM ThinkPad T30 Processor Replacement: step 3, image 3 of 3
      • Lift the keyboard to expose the ribbon connector and lean it against the computer screen to keep the ribbon intact.
      • If the ribbon is broken, the keyboard is permanently unusable and needs to be replaced
      • Use the plastic opening tool to gently pry the connector up from the motherboard.
      • You can now safely remove the keyboard.
      Ask FixBot
    1. IBM ThinkPad T30 Processor Replacement, Fan Assembly: step 4, image 1 of 2 IBM ThinkPad T30 Processor Replacement, Fan Assembly: step 4, image 2 of 2
      • Remove the three 4 mm Phillips #0 screws securing the fan assembly.
      Ask FixBot
    2. IBM ThinkPad T30 Processor Replacement: step 5, image 1 of 2 IBM ThinkPad T30 Processor Replacement: step 5, image 2 of 2
      • Using the plastic opening tool, gently pry the heat sink assembly up.
      • Be sure to reapply thermal compound on the processor and heat sink when reassembling the device.
      • Be aware that there still is a wire attached to the fan that is connected to motherboard upon removal.
      Ask FixBot
    3. IBM ThinkPad T30 Processor Replacement: step 6, image 1 of 2 IBM ThinkPad T30 Processor Replacement: step 6, image 2 of 2
      • Using the plastic opening tool, gently lift the white connector out of its socket on the motherboard.
      • Before installing the new fan, remove all remnants of thermal compound from the top of the CPU. Warning—the stuff is hard to clean off clothing. Spread a small amount of fresh heat sink compound (DC-340 or equivalent) on the top of the CPU to form a thin coat. Be sure the mating fan heat sink is clean.
      • Follow iFixit's guide for [invalid guide link] for a detailed explanation.
      Ask FixBot
    1. IBM ThinkPad T30 Processor Replacement, Processor: step 7, image 1 of 1
      • To remove the processor, set the dial on the processor socket to unlock using a small screwdriver.
      • Unscrew until the processor looks like it "lifts" a little.
      Ask FixBot
    2. IBM ThinkPad T30 Processor Replacement: step 8, image 1 of 1
      • Gently lift up one side of the processor to unseat, then remove completely from device.
      • Processor pins and corners are pointy--be careful!
      • Beware of the pins, don't bend them!
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
4 other people completed this guide.
Author
with
Alex Kost
271 Reputation
5 Guides authored
Cal Poly, Team 3-20, Amido Fall 2012 Member of Cal Poly, Team 3-20, Amido Fall 2012
CPSU-AMIDO-F12S3G20
3 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 108
All Time: 6,356
