Up to 20% off select tools
IBM ThinkPad R40 Keyboard Keys Replacement
Views: 5.7K
View statistics:
Past 24 Hours:
3
Past 7 Days:
22
Past 30 Days:
103
All Time:
5,659
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will show you every step needed to ensure proper process in replacing a keyboard key for the IBM ThinkPad R40.
    1. IBM ThinkPad R40 Keyboard Keys Replacement, Disconnection: step 1, image 1 of 1
      • Make sure your laptop is off and disconnected from the power source to ensure safety for yourself.
      Ask FixBot
    2. IBM ThinkPad R40 Keyboard Keys Replacement, Replacement: step 2, image 1 of 1
      Tool used on this step:
      Buy
      • Locate the key that needs replacing. Use tweezers to slowly pull the key off the keyboard. Doing this will expose the underside of the keyboard.
      Ask FixBot
    3. IBM ThinkPad R40 Keyboard Keys Replacement, Set aside: step 3, image 1 of 1
      • Step 3: Set the old key aside and have the new key ready to be inserted onto the computer. The key has three parts, which you can see here.
      Ask FixBot
    4. IBM ThinkPad R40 Keyboard Keys Replacement, Moving inside: step 4, image 1 of 1
      • The new key will have an empty slot where they key used to be. It contains a small rubber spring. After the rubber spring is inserted take the new key and line it up according to the color springs on the backside of the key along with the keyboard.
      Ask FixBot
    5. IBM ThinkPad R40 Keyboard Keys Replacement, Lining up: step 5, image 1 of 1
      • After lining the key up, the black and white pieces will line up.
      Ask FixBot
    6. IBM ThinkPad R40 Keyboard Keys Replacement, Finishing up: step 6, image 1 of 1
      • Step 6: The key should not be firmly locked into place and functioning normally.
      Ask FixBot
Author
with
Erin
231 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 103
All Time: 5,659
