Up to 20% off select tools
IBM ThinkPad A31 Keyboard Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
Past 7 Days:
9
Past 30 Days:
68
All Time:
1,178
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 6 minutes
Difficulty: Easy
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. IBM ThinkPad A31 Keyboard Replacement, Battery: step 1, image 1 of 2 IBM ThinkPad A31 Keyboard Replacement, Battery: step 1, image 2 of 2
      • Flip the ThinkPad over so that it is upside down.
      • Push latch switch to the left.
      • Gently lift the battery out and away from the ThinkPad
      • You have to hold the latch to the left while you remove the battery. Simply pushing once will not unlock the battery
      Ask FixBot
    1. IBM ThinkPad A31 Keyboard Replacement, Keyboard: step 2, image 1 of 3 IBM ThinkPad A31 Keyboard Replacement, Keyboard: step 2, image 2 of 3 IBM ThinkPad A31 Keyboard Replacement, Keyboard: step 2, image 3 of 3
      • The sticker is to keep the warranty on the laptop so once removed the warranty is void
      • Peel the sticker and remove the 15mm screw
      • Remove all 6 of the 16mm screws
      Ask FixBot
    2. IBM ThinkPad A31 Keyboard Replacement: step 3, image 1 of 2 IBM ThinkPad A31 Keyboard Replacement: step 3, image 2 of 2
      • use a prying tool and insert it on the cracks on the sides of the keyboard and lift gently until you here a click
      • repeat this step on all sides of the keyboard until the keyboard is completely detached from the laptop
      Ask FixBot
    3. IBM ThinkPad A31 Keyboard Replacement: step 4, image 1 of 3 IBM ThinkPad A31 Keyboard Replacement: step 4, image 2 of 3 IBM ThinkPad A31 Keyboard Replacement: step 4, image 3 of 3
      • Lift the keyboard and remove the keyboard ribbon cable from the laptop
      Ask FixBot
2 other people completed this guide.
Author
with
Matheus
128 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 68
All Time: 1,178
