Up to 20% off select tools
IBM ThinkPad A30 RAM Replacement
Views: 3.9K
View statistics:
Past 24 Hours:
2
Past 7 Days:
20
Past 30 Days:
87
All Time:
3,891
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Better Introduction
Improve this guide by completing or revising its introduction.
Parts
Tools
    1. IBM ThinkPad A30 RAM Replacement, Battery: step 1, image 1 of 2 IBM ThinkPad A30 RAM Replacement, Battery: step 1, image 2 of 2
      • Flip the ThinkPad over so that it is upside down.
      • Slide the highlighted tab to the left.
      • With your finger on the tab, remove the battery by lifting it upwards away from the laptop.
      Ask FixBot
    1. IBM ThinkPad A30 RAM Replacement, RAM: step 2, image 1 of 2 IBM ThinkPad A30 RAM Replacement, RAM: step 2, image 2 of 2
      • Remove the two 5.3mm cover screws.
      • Gently lift the cover containing the RAM.
      Ask FixBot
    2. IBM ThinkPad A30 RAM Replacement: step 3, image 1 of 1
      • Remove RAM module by pressing the two metal pieces outward with your thumbs.
      Ask FixBot
    3. IBM ThinkPad A30 RAM Replacement: step 4, image 1 of 2 IBM ThinkPad A30 RAM Replacement: step 4, image 2 of 2
      • Lift the RAM module up and out, away from the yellow connector.
      • Place the RAM module away from any magnets or static electricity prone areas.
      Ask FixBot
Author
with
Jessica
162 Reputation
7 Guides authored
Cal Poly, Team 4-44, Amido Fall 2010 Member of Cal Poly, Team 4-44, Amido Fall 2010
CPSU-AMIDO-F10S4G44
4 Members
156 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 87
All Time: 3,891
