Up to 20% off select tools
IBM ThinkPad 600E RAM Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
2
Past 7 Days:
21
Past 30 Days:
102
All Time:
1,841
Comments: 1
1 comment on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Easy
Step Trimmer
This guide has unnecessary steps. Trim them to be more concise!
Tools
Introduction
Go to step 1 ↓
This guide will show you how to replace the RAM from your laptop. There are several reasons to replace your RAM. The most common reason is to increase your RAM memory. Other reasons could be that it could faulty or damaged.
    1. IBM ThinkPad 600E RAM Replacement, Battery: step 1, image 1 of 3 IBM ThinkPad 600E RAM Replacement, Battery: step 1, image 2 of 3 IBM ThinkPad 600E RAM Replacement, Battery: step 1, image 3 of 3
      • Flip the laptop over and find the battery latch.
      Ask FixBot
    2. IBM ThinkPad 600E RAM Replacement: step 2, image 1 of 1
      • Move the latch to the side with the unlocked symbol.
      Ask FixBot
    3. IBM ThinkPad 600E RAM Replacement: step 3, image 1 of 3 IBM ThinkPad 600E RAM Replacement: step 3, image 2 of 3 IBM ThinkPad 600E RAM Replacement: step 3, image 3 of 3
      • Pry the battery out using your fingers.
      Ask FixBot
    1. IBM ThinkPad 600E RAM Replacement, RAM: step 4, image 1 of 1
      • Put on the anti-static wrist trap and clip it to a large metal object.
      • If you do not have an anti-static wristband, make sure to touch a large metal object to ground yourself before beginning to work on your replacement. Occasionally touch the metal object.
      Ask FixBot
    2. IBM ThinkPad 600E RAM Replacement: step 5, image 1 of 3 IBM ThinkPad 600E RAM Replacement: step 5, image 2 of 3 IBM ThinkPad 600E RAM Replacement: step 5, image 3 of 3
      • Using a screwdriver, loosen but do not remove the captive screw by turning counterclockwise.
      • One 3mm PH0 screw
      Ask FixBot
    3. IBM ThinkPad 600E RAM Replacement: step 6, image 1 of 3 IBM ThinkPad 600E RAM Replacement: step 6, image 2 of 3 IBM ThinkPad 600E RAM Replacement: step 6, image 3 of 3
      • Using your fingers, pry the small retention clips apart until the ram pops up.
      Ask FixBot
    4. IBM ThinkPad 600E RAM Replacement: step 7, image 1 of 2 IBM ThinkPad 600E RAM Replacement: step 7, image 2 of 2
      • Using your fingers, pull straight in line with the ram to remove it.
      Ask FixBot
    5. IBM ThinkPad 600E RAM Replacement: step 8, image 1 of 3 IBM ThinkPad 600E RAM Replacement: step 8, image 2 of 3 IBM ThinkPad 600E RAM Replacement: step 8, image 3 of 3
      • Repeat steps 3 and 4 if you want to remove the second ram stick.
      Ask FixBot
2 other people completed this guide.
Author
with
Harold Rocha
173 Reputation
1 Guide authored
USF Tampa, Team 1-4, Nance Fall 2016 Member of USF Tampa, Team 1-4, Nance Fall 2016
USFT-NANCE-F16S1G4
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 102
All Time: 1,841
