Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
Tools
Introduction
Go to step 1 ↓This guide will show you how to replace your display from your laptop. You would need to replace it if you break your display.
Tool used on this step:Anti-Static Wrist Strap$7.95
Unscrew the coin screw for the hard drive using a coin. Pry off the HDD cover.
Remove the plastic part attached to the bottom of the screen.
Gently pull it from one side and then from another.
