Up to 20% off select tools
IBM ThinkPad 560z Screen Replacement
Views: 5.7K
View statistics:
Past 24 Hours:
5
Past 7 Days:
17
Past 30 Days:
90
All Time:
5,744
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 15 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
This guide will demonstrate how to remove and replace the screen on an IBM ThinkPad 560z. A Phillips 00 screwdriver and a push pin are needed for this process.
    1. IBM ThinkPad 560z Screen Replacement, Battery Removal: step 1, image 1 of 1
      • Slide the battery release latch to the right.
      • Pull out the battery out towards the front of the device.
      Ask FixBot
    1. IBM ThinkPad 560z Screen Replacement, Screw Cover Removal: step 2, image 1 of 2 IBM ThinkPad 560z Screen Replacement, Screw Cover Removal: step 2, image 2 of 2
      • Remove the plastic screw covers, then remove the 3 Phillips screws under them.
      Ask FixBot
    2. IBM ThinkPad 560z Screen Replacement, Screen Bezel Removal: step 3, image 1 of 1
      • Insert the plastic opening tool between the front cover and back cover to pry open the screen case, then carefully pull the bezel off.
      Ask FixBot
    3. IBM ThinkPad 560z Screen Replacement, LCD Removal Preperation: step 4, image 1 of 1
      • Remove the four Phillips head screws.
      Ask FixBot
    4. IBM ThinkPad 560z Screen Replacement, Ribbon Cable Disconnection: step 5, image 1 of 1
      • Using your fingers or an Opening Tool, detach the connector on the right side of the screen.
      Ask FixBot
    5. IBM ThinkPad 560z Screen Replacement, LCD Removal: step 6, image 1 of 2 IBM ThinkPad 560z Screen Replacement, LCD Removal: step 6, image 2 of 2
      • Slowly pull back the screen from the top and disconnect the ribbon cable from the back to completely free the screen from the laptop.
      • The connector is very fragile, so be careful.
      Ask FixBot
2 other people completed this guide.
Author
with
John Allande
64 Reputation
1 Guide authored
Cal Poly, Team 26-27, Regan Spring 2010 Member of Cal Poly, Team 26-27, Regan Spring 2010
CPSU-REGAN-S10S26G27
3 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 17
Past 30 Days: 90
All Time: 5,744
