IBM ThinkPad 560z Keyboard Cover Replacement
    1. IBM ThinkPad 560z Keyboard Cover Replacement, Upper Case: step 1, image 1 of 1
      • Remove the 7 mm Phillips #0 screws.
      • Remove the 10 mm Phillips #0 screws.
      • Remove the 14 mm Phillips #0 screw.
      Ask FixBot
    2. IBM ThinkPad 560z Keyboard Cover Replacement: step 2, image 1 of 2 IBM ThinkPad 560z Keyboard Cover Replacement: step 2, image 2 of 2
      • Open the flap on the left hand side.
      Ask FixBot
    3. IBM ThinkPad 560z Keyboard Cover Replacement: step 3, image 1 of 2 IBM ThinkPad 560z Keyboard Cover Replacement: step 3, image 2 of 2
      • Insert the plastic opening tools between the right and left sides of the latch.
      • Pry the right side of the latch, and then pry the left side to detach the laptop's cover.
      Ask FixBot
    4. IBM ThinkPad 560z Keyboard Cover Replacement: step 4, image 1 of 2 IBM ThinkPad 560z Keyboard Cover Replacement: step 4, image 2 of 2
      • Open the flap on the right side.
      Ask FixBot
    5. IBM ThinkPad 560z Keyboard Cover Replacement: step 5, image 1 of 1
      • Insert the plastic opening tools towards the right side of the latch.
      • Gently pry the right side out to release the top cover.
      Ask FixBot
    6. IBM ThinkPad 560z Keyboard Cover Replacement: step 6, image 1 of 2 IBM ThinkPad 560z Keyboard Cover Replacement: step 6, image 2 of 2
      • Lift the keyboard slowly.
      • A cable connects the keyboard to the motherboard. If you are not careful, you will damage the cable.
      Ask FixBot
    7. IBM ThinkPad 560z Keyboard Cover Replacement: step 7, image 1 of 1
      • Use your fingers or a spudger to detach the connector.
      Ask FixBot
    8. IBM ThinkPad 560z Keyboard Cover Replacement: step 8, image 1 of 2 IBM ThinkPad 560z Keyboard Cover Replacement: step 8, image 2 of 2
      • Carefully lift and remove the keyboard.
      Ask FixBot
Derek Driscoll
119 Reputation
8 Guides authored
Cal Poly, Team 26-27, Regan Spring 2010 Member of Cal Poly, Team 26-27, Regan Spring 2010
CPSU-REGAN-S10S26G27
3 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 19
All Time: 2,233
