HyperX QuadCast S Gain Control Knob Replacement
Views: 3K
View statistics:
Past 24 Hours:
6
Past 7 Days:
31
Past 30 Days:
127
All Time:
3,017
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
If your microphone has any distortion in tone, such as the audio being too quiet, or too loud, then there may be a problem with the gain control knob. This guide will demonstrate how to simply remove the gain control knob, which can allow access to the I/O board of the microphone. Keep in mind that this guide highlights removing the gain control knob, and not how to remove the I/O board.
    1. HyperX QuadCast S Gain Control Knob Replacement, Gain Control Knob: step 1, image 1 of 3 HyperX QuadCast S Gain Control Knob Replacement, Gain Control Knob: step 1, image 2 of 3 HyperX QuadCast S Gain Control Knob Replacement, Gain Control Knob: step 1, image 3 of 3
      • Set the microphone on a flat surface.
      • Pull each of the support bands upwards and off of the notches to release the microphone from its base.
      • There are four support bands in total, but it does not matter which band you choose to take off first.
      Ask FixBot
    2. HyperX QuadCast S Gain Control Knob Replacement: step 2, image 1 of 3 HyperX QuadCast S Gain Control Knob Replacement: step 2, image 2 of 3 HyperX QuadCast S Gain Control Knob Replacement: step 2, image 3 of 3
      • Orientate the microphone with the gain control knob upwards.
      • Pull outwards from the microphone to release the gain control knob.
      • It will not take much force to release the knob from the microphone. Be aware that a small "pop" may be heard once the knob is unplugged.
      Ask FixBot
    3. HyperX QuadCast S Gain Control Knob Replacement: step 3, image 1 of 3 HyperX QuadCast S Gain Control Knob Replacement: step 3, image 2 of 3 HyperX QuadCast S Gain Control Knob Replacement: step 3, image 3 of 3
      • Remove the gain control knob.
      • The gain control knob connects to the tiny black pin indicated. When reattaching the knob, make sure to properly align the hole to the shape of the pin.
      Ask FixBot
Nathan Arruda
765 Reputation
6 Guides authored
UMass Dartmouth, Team 4-1, Sinclaire Fall 2022 Member of UMass Dartmouth, Team 4-1, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S4G1
5 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 31
Past 30 Days: 127
All Time: 3,017
