HyperX CloudX Flight Charging Port Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
20
Past 30 Days:
82
All Time:
783
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Introduction
Go to step 1 ↓
Over time, foreign material will enter the charging port of your HyperX CloudX Flight and degrade naturally. This can sometimes lead to issues with charging your device. Replacing the port is easy and requires minimal soldering knowledge.
Tools
    1. HyperX CloudX Flight Charging Port Replacement, Charging Port: step 1, image 1 of 1
      • Place the device on a flat surface and orient the ear cups towards yourself.
      Ask FixBot
    2. HyperX CloudX Flight Charging Port Replacement: step 2, image 1 of 2 HyperX CloudX Flight Charging Port Replacement: step 2, image 2 of 2
      • Gently pull around the perimeter of the left ear cup until the cushion is fully removed.
      Ask FixBot
    3. HyperX CloudX Flight Charging Port Replacement: step 3, image 1 of 1
      • Use a small Phillips screwdriver to remove the base plate.
      Ask FixBot
    4. HyperX CloudX Flight Charging Port Replacement: step 4, image 1 of 1
      • After removing the plate, locate the charging port on the board. You can carefully desolder the charging port from the board by pointing the tip of your soldering iron to melt the existing connections.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Ensure to carefully resolder the USB port as to not interfere with other connections.
1 Guide Comment
Where do I get another charging port?
NeighborhoodQuailGuy - Reply Share
Past 24 Hours: 1
Past 7 Days: 20
Past 30 Days: 82
All Time: 783
