HyperX Alloy Origins Frontplate Replacement
  1. HyperX Alloy Origins Frontplate Replacement, Toggle Indicator Tab: step 1, image 1 of 1
    • Locate the toggle indicator tab on the top right corner of the keyboard.
    Ask FixBot
  2. HyperX Alloy Origins Frontplate Replacement: step 2, image 1 of 2 HyperX Alloy Origins Frontplate Replacement: step 2, image 2 of 2
    • Insert the metal spudger or some other separating instrument into the right crevasse between the tab and the keyboard.
    • Lift up gently on the tab, while holding the left side of the tab down.
    • The tab can spring upwards upon removal. Eye protection is recommended during this step.
    Ask FixBot
  3. HyperX Alloy Origins Frontplate Replacement, Backplate: step 3, image 1 of 2 HyperX Alloy Origins Frontplate Replacement, Backplate: step 3, image 2 of 2
    • Flip the keyboard over so that the backplate is facing you.
    Ask FixBot
  4. HyperX Alloy Origins Frontplate Replacement: step 4, image 1 of 3 HyperX Alloy Origins Frontplate Replacement: step 4, image 2 of 3 HyperX Alloy Origins Frontplate Replacement: step 4, image 3 of 3
    • Remove the rubber feet on the four corners of the backplate.
    • When reassembling, use an adhesive to reattach the feet. A silicone rubber adhesive is recommended.
    Ask FixBot
  5. HyperX Alloy Origins Frontplate Replacement: step 5, image 1 of 3 HyperX Alloy Origins Frontplate Replacement: step 5, image 2 of 3 HyperX Alloy Origins Frontplate Replacement: step 5, image 3 of 3
    • Remove the specified keycaps as depicted in the image.
    Ask FixBot
  6. HyperX Alloy Origins Frontplate Replacement: step 6, image 1 of 3 HyperX Alloy Origins Frontplate Replacement: step 6, image 2 of 3 HyperX Alloy Origins Frontplate Replacement: step 6, image 3 of 3
    • Remove all Philips #0 screws from the new openings created after removing the rubber feet and plastic tab.
    Ask FixBot
  7. HyperX Alloy Origins Frontplate Replacement: step 7, image 1 of 3 HyperX Alloy Origins Frontplate Replacement: step 7, image 2 of 3 HyperX Alloy Origins Frontplate Replacement: step 7, image 3 of 3
    • Separate the backplate from the keyboard using your hands.
    Ask FixBot
  8. HyperX Alloy Origins Frontplate Replacement, Key Switch: step 8, image 1 of 3 HyperX Alloy Origins Frontplate Replacement, Key Switch: step 8, image 2 of 3 HyperX Alloy Origins Frontplate Replacement, Key Switch: step 8, image 3 of 3
    • Identify the key switch to be replaced.
    • Remove its keycap by carefully prying it off of the keyboard with your fingers.
    Ask FixBot
  9. HyperX Alloy Origins Frontplate Replacement: step 9, image 1 of 2 HyperX Alloy Origins Frontplate Replacement: step 9, image 2 of 2
    • Flip the keyboard over to face the PCB.
    • Identify the corresponding switch to be removed.
    Ask FixBot
  10. HyperX Alloy Origins Frontplate Replacement: step 10, image 1 of 1
    • Plug in and turn on your soldering iron.
    • Do not touch the metal end of the soldering iron while it is powered on. Allow the soldering iron to cool before stowing it away.
    Ask FixBot
  11. HyperX Alloy Origins Frontplate Replacement: step 11, image 1 of 3 HyperX Alloy Origins Frontplate Replacement: step 11, image 2 of 3 HyperX Alloy Origins Frontplate Replacement: step 11, image 3 of 3
    Tool used on this step:
    Desoldering Pump
    $3.99
    Buy
    • Melt the solder surrounding the four pins of the switch's LED, and the two lower pins of the switch body.
    • To remove the melted solder, use a desoldering iron, a desoldering pump, or desoldering braid.
    • The exposed switch pins are susceptible to damage from the soldering iron. Avoid applying heavy pressure to mitigate pin bending.
    Ask FixBot
  12. HyperX Alloy Origins Frontplate Replacement: step 12, image 1 of 1
    • Using a spudger or another metallic instrument, firmly press down upon the exposed plastic of the switch. This will separate the switch from the rest of the keyboard.
    • If the switch's pins will not separate from the keyboard's PCB, continue applying the soldering iron to the pins to melt any residual solder.
    Ask FixBot
  13. HyperX Alloy Origins Frontplate Replacement, Frontplate: step 13, image 1 of 1
    • Desolder and separate every key switch from the keyboard.
    • The keyboard microcontrollers should remain on the PCB and should not be desoldered.
    Ask FixBot
    • Separate the frontplate from the keyboard PCB using your hands.
    • Set the PCB aside upon the backplate.
    Ask FixBot
To reassemble your device, follow these instructions in reverse order. Note that when reattaching the switches back onto the keyboard PCB, the switches need to be held in place behind the keyboard while soldering.
Zachary Lapalme
85 Reputation
1 Guide authored
UMass Dartmouth, Team 5-2, Sinclaire Fall 2022 Member of UMass Dartmouth, Team 5-2, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S5G2
5 Members
15 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 40
All Time: 1,651
