Hyper Mega Tech! Taito Super Pocket Back Buttons Replacement
    1. Hyper Mega Tech! Taito Super Pocket Back Buttons Replacement, Back Panel: step 1, image 1 of 1
      • Power the device off before starting the disassembly process.
      Ask FixBot
    2. Hyper Mega Tech! Taito Super Pocket Back Buttons Replacement: step 2, image 1 of 2 Hyper Mega Tech! Taito Super Pocket Back Buttons Replacement: step 2, image 2 of 2
      • Face the back of the device, then remove the Super Pocket gaming cartridge from the device.
      Ask FixBot
    3. Hyper Mega Tech! Taito Super Pocket Back Buttons Replacement: step 3, image 1 of 1
      • Use a Phillips #000 screwdriver to remove the four 2 mm screws from the four corners.
      Ask FixBot
    4. Hyper Mega Tech! Taito Super Pocket Back Buttons Replacement: step 4, image 1 of 2 Hyper Mega Tech! Taito Super Pocket Back Buttons Replacement: step 4, image 2 of 2
      • Face the front of the device and use the iFixit opening tool to lift the front panel from the back cover.
      • Be careful not to pull the two sides quickly, as they are connected by a battery cable, and it can be damaged if pulled too hard.
      Ask FixBot
    5. Hyper Mega Tech! Taito Super Pocket Back Buttons Replacement: step 5, image 1 of 1
      • Disconnect the battery cord connecting the two sides with tweezers.
      Ask FixBot
    1. Hyper Mega Tech! Taito Super Pocket Back Buttons Replacement, Back Buttons: step 6, image 1 of 1
      • With the back of the PCB exposed, use a soldering iron to apply heat to all four pads.
      • The soldering iron gets very hot.
      Ask FixBot
    2. Hyper Mega Tech! Taito Super Pocket Back Buttons Replacement: step 7, image 1 of 3 Hyper Mega Tech! Taito Super Pocket Back Buttons Replacement: step 7, image 2 of 3 Hyper Mega Tech! Taito Super Pocket Back Buttons Replacement: step 7, image 3 of 3
      • Gently grab the button using tweezers and lift the button off the PCB.
      • Repeat this step for every button that needs to be replaced.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 22
All Time: 126
