Up to 20% off select tools
Humax RM-H01U Remote Disassembly
Views: 1.2K
View statistics:
Past 24 Hours:
4
Past 7 Days:
24
Past 30 Days:
113
All Time:
1,150
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
  • Spudger
    4.9
Introduction
Go to step 1 ↓
My remote wouldn't respond to some button presses anymore. The contacts became dirty after long use. So I opened it and cleaned the contacts. (I used pure alcohol - please take care not to brush off the carbon layer of the buttons.)
    1. Humax RM-H01U Remote Disassembly, The Humax RM-H01U remote: step 1, image 1 of 2 Humax RM-H01U Remote Disassembly, The Humax RM-H01U remote: step 1, image 2 of 2
      • The remote has a bottom and top part. They are held together with plastic clips.
      • Don't forget to remove the battery, just for good measure.
      Ask FixBot
    2. Humax RM-H01U Remote Disassembly, Opening using a spudger: step 2, image 1 of 3 Humax RM-H01U Remote Disassembly, Opening using a spudger: step 2, image 2 of 3 Humax RM-H01U Remote Disassembly, Opening using a spudger: step 2, image 3 of 3
      • Use a spudger, prying tool or a flatbed screwdriver to pry open the two halves. Start at the center.
      • The two halves are clamped together firmly.
      • Work your way to the front, and then back again on the other side.
      • See the next step for the location of the clips.
      Ask FixBot
    3. Humax RM-H01U Remote Disassembly, Clip locations: step 3, image 1 of 1
      • The clips are located 3 centimeters apart. The first clip is 1 centimeter from the front of the remote.
      • The hooks of the clips are on the bottom halve of the remote and face inward.
      • The top halve of the remote has indents where the clips grab into.
      Ask FixBot
    4. Humax RM-H01U Remote Disassembly, All parts of the remote: step 4, image 1 of 1
      • These are all the parts.
      • I cleaned all parts with a toothbrush first.
      • Then I cleaned the PCB and the back of the silicone buttons with pure alcohol.
      • Make sure not to brush too hard! You might remove the carbon layer that is applied. (It's the carbon layer that makes the electrical connection, so it's essential).
      Ask FixBot
Author
with
Jurrie
763 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 24
Past 30 Days: 113
All Time: 1,150
