Up to 20% off select tools
Huawei u7519 Camera Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
2
Past 30 Days:
26
All Time:
968
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 20 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Huawei u7519 Camera Replacement, Back Cover: step 1, image 1 of 2 Huawei u7519 Camera Replacement, Back Cover: step 1, image 2 of 2
      • Take off the back covering of the phone along with the battery and SIM card.
      • The SIM card is located above the battery.
      Ask FixBot
    2. Huawei u7519 Camera Replacement: step 2, image 1 of 2 Huawei u7519 Camera Replacement: step 2, image 2 of 2
      • Using the Phillips #00 Screwdriver, take out the four small screws located at the four corners of the phone.
      Ask FixBot
    3. Huawei u7519 Camera Replacement: step 3, image 1 of 1
      • Using the same screwdriver, take out the two bigger screws located on each side of the battery compartment.
      Ask FixBot
    4. Huawei u7519 Camera Replacement: step 4, image 1 of 1
      • Once all the screws are removed, use the iPod opening tool to pry off the back covering of the phone along the edge of the back cover and you will have access to the motherboard.
      • The power and volume buttons will fall out of the phone. Set aside for reassembly.
      Ask FixBot
    5. Huawei u7519 Camera Replacement: step 5, image 1 of 1
      • Carefully pull the backing of the phone from the motherboard with your hands.
      Ask FixBot
    1. Huawei u7519 Camera Replacement, Camera: step 6, image 1 of 2 Huawei u7519 Camera Replacement, Camera: step 6, image 2 of 2
      • To remove front encasing from the motherboard, first pull back the orange tabs.
      Ask FixBot
    2. Huawei u7519 Camera Replacement: step 7, image 1 of 2 Huawei u7519 Camera Replacement: step 7, image 2 of 2
      • Once the orange tabs are pulled back, carefully pull the motherboard apart from the front casing.
      Ask FixBot
    3. Huawei u7519 Camera Replacement: step 8, image 1 of 1
      • The camera is not removable from the motherboard. Therefore, a new motherboard must be purchased in order to replace the camera.
      Ask FixBot
2 other people completed this guide.
Author
with
Marcus Mamarella
36 Reputation
1 Guide authored
Ohio State, Team 1-1, Meza Spring 2014 Member of Ohio State, Team 1-1, Meza Spring 2014
OSU-MEZA-S14S1G1
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 26
All Time: 968
