Up to 20% off select tools
Huawei Y7 2019 Screen Replacement
Views: 11K
View statistics:
Past 24 Hours:
4
Past 7 Days:
32
Past 30 Days:
199
All Time:
11,180
Comments: 1
1 guide comment.
Go to guide comments
Completed: 26
26 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
How to change a broken screen on your Huawei Y7 2019.
Video Overview
Video Tutorial for Huawei Y7 2019 Screen replacement
    1. Huawei Y7 2019 Screen Replacement, Display replacement without frame: step 1, image 1 of 1
      • The new spare screen that will be installed on the phone.
      Ask FixBot
    2. Huawei Y7 2019 Screen Replacement, Remove the Cover: step 2, image 1 of 3 Huawei Y7 2019 Screen Replacement, Remove the Cover: step 2, image 2 of 3 Huawei Y7 2019 Screen Replacement, Remove the Cover: step 2, image 3 of 3
      • Remove the SIM Tray.
      • Use a plastic tool such as a spudger or opening pick to remove the back cover.
      Ask FixBot
    3. Huawei Y7 2019 Screen Replacement: step 3, image 1 of 3 Huawei Y7 2019 Screen Replacement: step 3, image 2 of 3 Huawei Y7 2019 Screen Replacement: step 3, image 3 of 3
      • Remove the seven Phillips screws that are above the battery.
      • Remove the motherboard plastic cover.
      • Disconnect the battery and the fingerprint flex cable using a plastic pry tool.
      Ask FixBot
    4. Huawei Y7 2019 Screen Replacement: step 4, image 1 of 2 Huawei Y7 2019 Screen Replacement: step 4, image 2 of 2
      • Disconnect the screen flex cable and connect the new screen for testing.
      • If the spare part is fully functioning, then continue with the installation.
      Ask FixBot
    5. Huawei Y7 2019 Screen Replacement, Charging board cover removal: step 5, image 1 of 3 Huawei Y7 2019 Screen Replacement, Charging board cover removal: step 5, image 2 of 3 Huawei Y7 2019 Screen Replacement, Charging board cover removal: step 5, image 3 of 3
      • Remove the seven Phillips screws from the charging dock cover.
      • Remove the charging dock cover.
      • Lift the board slightly to release the screen flex cable.
      • Be gentle when removing the connectors, they are easy to break!
      Ask FixBot
    6. Huawei Y7 2019 Screen Replacement: step 6, image 1 of 3 Huawei Y7 2019 Screen Replacement: step 6, image 2 of 3 Huawei Y7 2019 Screen Replacement: step 6, image 3 of 3
      • Warm up the glass to soften the adhesive.
      • Use plastic tools to remove the glass, then clean the adhesive off the frame.
      • Be careful when working with broken glass. Use gloves and safety glasses to protect yourself, and try to keep the glass contained.
      Ask FixBot
    7. Huawei Y7 2019 Screen Replacement, Apply new adhesive: step 7, image 1 of 3 Huawei Y7 2019 Screen Replacement, Apply new adhesive: step 7, image 2 of 3 Huawei Y7 2019 Screen Replacement, Apply new adhesive: step 7, image 3 of 3
      Tool used on this step:
      Tesa 61395 Tape
      $8.95
      Buy
      • Apply 1 mm‑wide strips of thin, double‑sided tape to the long edges of the frame.
      • Apply a little glue (B-7000, E-8000, T-8000, or similar) to the corners of the frame.
      Ask FixBot
    8. Huawei Y7 2019 Screen Replacement: step 8, image 1 of 2 Huawei Y7 2019 Screen Replacement: step 8, image 2 of 2
      • Install the new screen.
      • Use clamps until the glue dries.
      Ask FixBot
26 other people completed this guide.
Author
with
ZFix
197,930 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
337 Members
8,294 Guides authored
1 Guide Comment
C'est très bon comme site
aristide kévin kouamé - Reply Share
Past 24 Hours: 4
Past 7 Days: 32
Past 30 Days: 199
All Time: 11,180
