Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement
Video Overview
    1. Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Switch off the device: step 1, image 1 of 3 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Switch off the device: step 1, image 2 of 3 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Switch off the device: step 1, image 3 of 3
      • Turn off the device
      • Remove the sim tray
      Ask FixBot
    2. Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Back Cover: step 2, image 1 of 3 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Back Cover: step 2, image 2 of 3 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Back Cover: step 2, image 3 of 3
      • Use Plastic tool to separate the back cover
      • With a Phillips screwdriver remove two black screws and the battery flex connector shield
      • Disconnect the battery and the finger print sensor flex cable
      Ask FixBot
    3. Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Logic Board Removal Part 1: step 3, image 1 of 3 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Logic Board Removal Part 1: step 3, image 2 of 3 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Logic Board Removal Part 1: step 3, image 3 of 3
      • Remove all screws from the top of the logic board
      • Remove the shield covering the camera connectors
      • Remove the screws and the plastic cover at the bottom of the device
      • Be careful! Different colored screws have different size
      Ask FixBot
    4. Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Logic Board Removal - Part 2: step 4, image 1 of 3 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Logic Board Removal - Part 2: step 4, image 2 of 3 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Logic Board Removal - Part 2: step 4, image 3 of 3
      • Disconnect the Screen Flex cable
      • Remove the logic board
      • Note that at the bottom side of board is attached to the display with double-sided tape
      Ask FixBot
    5. Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement: step 5, image 1 of 3 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement: step 5, image 2 of 3 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement: step 5, image 3 of 3
      • Now you have to transfer:
      • Receiver
      • Proximity sensor
      • Volume buttons flex
      • Vibration
      • Battery
      Ask FixBot
14 other people completed this guide.
ZFix
197,561 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
334 Members
8,250 Guides authored
1 Guide Comment
Can i get video guide
filmon - Reply Share
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 91
All Time: 8,855
