Up to 20% off select tools
Huawei Y300 SIM Card Replacement
Views: 5.7K
View statistics:
Past 24 Hours:
4
Past 7 Days:
27
Past 30 Days:
116
All Time:
5,739
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
    1. Huawei Y300 SIM Card Replacement, Rear Cover: step 1, image 1 of 3 Huawei Y300 SIM Card Replacement, Rear Cover: step 1, image 2 of 3 Huawei Y300 SIM Card Replacement, Rear Cover: step 1, image 3 of 3
      • First, you want to flip the phone screen facing down. To remove the rear cover located on the back of the phone, you must grip on the gap located at the bottom of the phone. Lastly, pull up!
      Ask FixBot
    2. Huawei Y300 SIM Card Replacement: step 2, image 1 of 1
      • In order to remove the battery, you must first locate the gap intended for removal above the battery. You will then push down using the tip of your finger while also pulling outward to remove the battery for replacement.
      Ask FixBot
    3. Huawei Y300 SIM Card Replacement, Replace The Battery: step 3, image 1 of 1
      • After the battery is removed, you must replace the battery using the new one. To insert the new battery you must align the connection between the battery and the device. Lastly, you will push the bottom of the new battery until it is sitting inside the intended station.
      • This will be your new source of power.
      Ask FixBot
    1. Huawei Y300 SIM Card Replacement, SIM Card: step 4, image 1 of 1
      • Remove the SIM card by sliding it upwards.
      • The gold plate on the SIM card should faced the back of the phone and the little dent sits at the bottom right.
      • Huawei Y300 will not accept micro SIM card.
      Ask FixBot
5 other people completed this guide.
Author
with
Anthony Ng
1,454 Reputation
2 Guides authored
1 Guide Comment
My Huawei Y300 doesn't read the Sim card when inserted. Why?
Evelyn - Reply Share
Past 24 Hours: 4
Past 7 Days: 27
Past 30 Days: 116
All Time: 5,739
