Huawei Y300 Charging Port Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
Past 7 Days:
15
Past 30 Days:
64
All Time:
1,584
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 45 minutes
Difficulty: Difficult
Introduction
Go to step 1 ↓
In this guide we are going to replace the charging report on the Huawei ascend Y300 android smartphone. Before starting, it is a good idea to prepare an organized area to carry out the repair. It is also helpful to have a way of containing loose screws so they do not become lost. In addition, his guide requires soldering, a “How To” guide is included.
Tools
    1. Huawei Y300 Charging Port Replacement, Charging Port: step 1, image 1 of 2 Huawei Y300 Charging Port Replacement, Charging Port: step 1, image 2 of 2
      • Remove the back plate by hand. There is a small indent on the bottom of the phone to pry open.
      Ask FixBot
    2. Huawei Y300 Charging Port Replacement: step 2, image 1 of 1
      • Lift up and remove the battery.
      Ask FixBot
    3. Huawei Y300 Charging Port Replacement: step 3, image 1 of 2 Huawei Y300 Charging Port Replacement: step 3, image 2 of 2
      • Use a T4 Torx screwdriver to remove the 8 screws along the outer edge of the case.
      Ask FixBot
    4. Huawei Y300 Charging Port Replacement: step 4, image 1 of 2 Huawei Y300 Charging Port Replacement: step 4, image 2 of 2
      • Using the plastic opening tool, pry the screen from the casing. Insert the tool between the case and screen to pry the pieces apart.
      • Take care to not damage the screen or case.
      Ask FixBot
    5. Huawei Y300 Charging Port Replacement: step 5, image 1 of 2 Huawei Y300 Charging Port Replacement: step 5, image 2 of 2
      • Use a soldering iron to desolder the four connections to the charging port.
      • For information regarding how to properly solder, click the following link. How To Solder and Desolder Connections.
      Ask FixBot
3 other people completed this guide.
Alec Schory
193 Reputation
1 Guide authored
IUPUI, Team S3-G5, Harley Spring 2019 Member of IUPUI, Team S3-G5, Harley Spring 2019
IUPUI-HARLEY-S19S3G5
3 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 64
All Time: 1,584
