Huawei Watch Jewel Motherboard Replacement
Views: 3.9K
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
99
All Time:
3,877
Comments: 4
3 comments on steps, 1 guide comment.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to replace the motherboard in your Huawei Watch Jewel. A damaged motherboard could be the cause for several different malfunctions regarding the watch, as it acts as the brain of the device. The screws used to hold together the watch are quite small, so handle them with care.
Parts
Tools
    1. Huawei Watch Jewel Motherboard Replacement, Strap: step 1, image 1 of 2 Huawei Watch Jewel Motherboard Replacement, Strap: step 1, image 2 of 2
      • Begin by laying the watch on a flat, smooth surface.
      • This will prevent the watch screen from suffering damage.
      • Obtain a Flex Extension with a Size 1.0 mm flat-head. In the case of not having said tool, for this model of watch one can use the hands to replace the strap.
      Ask FixBot
    2. Huawei Watch Jewel Motherboard Replacement: step 2, image 1 of 2 Huawei Watch Jewel Motherboard Replacement: step 2, image 2 of 2
      • Locate the two springs on the back of your watch.
      • The watch comes with two of these springs on each side of the back-face. These are used to release the straps from the body of the watch.
      Ask FixBot
    3. Huawei Watch Jewel Motherboard Replacement: step 3, image 1 of 3 Huawei Watch Jewel Motherboard Replacement: step 3, image 2 of 3 Huawei Watch Jewel Motherboard Replacement: step 3, image 3 of 3
      • Use the Flex Extension to push the spring to the right. This will release the strap from the watch head.
      Ask FixBot
    4. Huawei Watch Jewel Motherboard Replacement: step 4, image 1 of 1
      • Carefully pull the strap away from the watch.
      Ask FixBot
    5. Huawei Watch Jewel Motherboard Replacement: step 5, image 1 of 2 Huawei Watch Jewel Motherboard Replacement: step 5, image 2 of 2
      • Repeat step 3, this time using the other strap.
      Ask FixBot
    1. Huawei Watch Jewel Motherboard Replacement, Motherboard: step 6, image 1 of 1
      • Locate the 4 T3 screws in the back of your watch, and use the T3 Torx Screwdriver to unscrew them.
      Ask FixBot
    2. Huawei Watch Jewel Motherboard Replacement: step 7, image 1 of 2 Huawei Watch Jewel Motherboard Replacement: step 7, image 2 of 2
      • Use the Metal Spudger to pry open the back of your watch.
      • Make sure the watch is off and not plugged in when prying into the case with the Metal Spudger to avoid the risk of electric shock.
      Ask FixBot
    3. Huawei Watch Jewel Motherboard Replacement: step 8, image 1 of 1
      • Remove the back case.
      Ask FixBot
    4. Huawei Watch Jewel Motherboard Replacement: step 9, image 1 of 2 Huawei Watch Jewel Motherboard Replacement: step 9, image 2 of 2
      Tool used on this step:
      Buy
      • Use tweezers or a nylon spudger to pry up the four press-fit connectors.
      • The glued-down connector in the middle is harder to remove than the rest. That is perfectly fine.
      Ask FixBot
    5. Huawei Watch Jewel Motherboard Replacement: step 10, image 1 of 1
      • Locate the two Phillips #00 screws holding down the motherboard, and use the Phillips #00 screwdriver to remove them.
      • Ensure to place these screws separately from the Torx screws, as they can easily be mixed up.
      Ask FixBot
    6. Huawei Watch Jewel Motherboard Replacement: step 11, image 1 of 1
      Spudger
      $2.99
      Buy
      • Use the Metal Spudger to lift the mother board from the watch.
      • The metal spudger may cause damage to the device, use a black nylon spudger when possible.
      Ask FixBot
    7. Huawei Watch Jewel Motherboard Replacement: step 12, image 1 of 1
      • Remove the motherboard.
      Ask FixBot
3 other people completed this guide.
ngan tran
526 Reputation
2 Guides authored
USF Tampa, Team 5-3, Passmore Spring 2017 Member of USF Tampa, Team 5-3, Passmore Spring 2017
USFT-PASSMORE-S17S5G3
4 Members
36 Guides authored
1 Guide Comment
where i can i buy Huawei Watch Jewel Motherboard online?
Mao Sereivathanak - Reply Share
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 99
All Time: 3,877
