Huawei Watch Jewel Battery Replacement
Views: 25K
View statistics:
Past 24 Hours:
4
Past 7 Days:
15
Past 30 Days:
126
All Time:
24,656
Comments: 13
5 comments on steps, 8 guide comments.
Go to guide comments
Completed: 21
21 people have marked this guide "completed." Will you be next?
Favorites: 5
5 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
A watch's battery is responsible for maintaining the life-time of the watch. Therefore, a damaged battery will take away from the enjoyment of the watch. This guide highlights the steps required to replace the Huawei Jewel Battery. It can be a relatively difficult process, so follow all steps carefully.
Tools
    1. Huawei Watch Jewel Battery Replacement, Strap: step 1, image 1 of 2 Huawei Watch Jewel Battery Replacement, Strap: step 1, image 2 of 2
      • Begin by laying the watch on a flat, smooth surface.
      • This will prevent the watch screen from suffering damage.
      • Obtain a Flex Extension with a Size 1.0 mm flat-head. In the case of not having said tool, for this model of watch one can use the hands to replace the strap.
      Ask FixBot
    2. Huawei Watch Jewel Battery Replacement: step 2, image 1 of 2 Huawei Watch Jewel Battery Replacement: step 2, image 2 of 2
      • Locate the two springs on the back of your watch.
      • The watch comes with two of these springs on each side of the back-face. These are used to release the straps from the body of the watch.
      Ask FixBot
    3. Huawei Watch Jewel Battery Replacement: step 3, image 1 of 3 Huawei Watch Jewel Battery Replacement: step 3, image 2 of 3 Huawei Watch Jewel Battery Replacement: step 3, image 3 of 3
      • Use the Flex Extension to push the spring to the right. This will release the strap from the watch head.
      Ask FixBot
    4. Huawei Watch Jewel Battery Replacement: step 4, image 1 of 1
      • Carefully pull the strap away from the watch.
      Ask FixBot
    5. Huawei Watch Jewel Battery Replacement: step 5, image 1 of 2 Huawei Watch Jewel Battery Replacement: step 5, image 2 of 2
      • Repeat step 3, this time using the other strap.
      Ask FixBot
    1. Huawei Watch Jewel Battery Replacement, Motherboard: step 6, image 1 of 1
      • Locate the 4 T3 screws in the back of your watch, and use the T3 Torx Screwdriver to unscrew them.
      Ask FixBot
    2. Huawei Watch Jewel Battery Replacement: step 7, image 1 of 2 Huawei Watch Jewel Battery Replacement: step 7, image 2 of 2
      • Use the Metal Spudger to pry open the back of your watch.
      • Make sure the watch is off and not plugged in when prying into the case with the Metal Spudger to avoid the risk of electric shock.
      Ask FixBot
    3. Huawei Watch Jewel Battery Replacement: step 8, image 1 of 1
      • Remove the back case.
      Ask FixBot
    4. Huawei Watch Jewel Battery Replacement: step 9, image 1 of 2 Huawei Watch Jewel Battery Replacement: step 9, image 2 of 2
      Tool used on this step:
      Buy
      • Use tweezers or a nylon spudger to pry up the four press-fit connectors.
      • The glued-down connector in the middle is harder to remove than the rest. That is perfectly fine.
      Ask FixBot
    5. Huawei Watch Jewel Battery Replacement: step 10, image 1 of 1
      • Locate the two Phillips #00 screws holding down the motherboard, and use the Phillips #00 screwdriver to remove them.
      • Ensure to place these screws separately from the Torx screws, as they can easily be mixed up.
      Ask FixBot
    6. Huawei Watch Jewel Battery Replacement: step 11, image 1 of 1
      Spudger
      $2.99
      Buy
      • Use the Metal Spudger to lift the mother board from the watch.
      • The metal spudger may cause damage to the device, use a black nylon spudger when possible.
      Ask FixBot
    7. Huawei Watch Jewel Battery Replacement: step 12, image 1 of 1
      • Remove the motherboard.
      Ask FixBot
    1. Huawei Watch Jewel Battery Replacement, Battery: step 13, image 1 of 1
      iFixit Opening Picks (Set of 6)
      $4.95
      Buy
      • Use the spudger or opening pick to carefully lift the battery from the watch.
      • Ensure that the polarity (+/- signs) of the new battery match that of the old battery when inserting new battery into device.
      • Avoid using a metal spudger as it may cause damage to the battery or device. Use an opening pick when possible.
      Ask FixBot
21 other people completed this guide.
ngan tran
526 Reputation
2 Guides authored
USF Tampa, Team 5-3, Passmore Spring 2017 Member of USF Tampa, Team 5-3, Passmore Spring 2017
USFT-PASSMORE-S17S5G3
4 Members
36 Guides authored
8 Guide Comments
Any idea where one can purchase the actual battery? I can’t find one anywhere.
Chris Wellings - Reply Share
@Chris wellings: i was able to find one on ebay. Arrived quite quickly. And you definitely need a T2(not 3) screwdriver to open up the watch.
edgar.dumea - Reply Share
Also found one on eBay. I was replacing the battery on the standard Huawei Watch (W1) and this guide was really helpful.
Alex Swanson - Reply Share
thanks for this great guide, it’s very clear. My W1’s battery is still OK, but I’m anticipating needing to change it sometime and your guide removes the fear!
Paul M - Reply Share
T2 or T3 Torx ???
Carlos - Reply Share
Past 24 Hours: 4
Past 7 Days: 15
Past 30 Days: 126
All Time: 24,656
