Huawei Watch 2 Opening Procedure
Views: 8.3K
View statistics:
Past 24 Hours:
4
Past 7 Days:
29
Past 30 Days:
141
All Time:
8,342
Comments: 4
1 comment on steps, 3 guide comments.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to open your Huawei Watch 2 for repairs.
Tools
    1. Huawei Watch 2 Opening Procedure, Huawei Watch 2 Opening Procedure: step 1, image 1 of 1
      • Before starting repairs, take your watch off the charger and power it down.
      • Feel free to attach or remove the watch band as needed to provide more control as you make repairs.
      Ask FixBot
    2. Huawei Watch 2 Opening Procedure: step 2, image 1 of 1
      • Remove the four Torx T2 screws (4.5 mm length).
      Ask FixBot
    3. Huawei Watch 2 Opening Procedure: step 3, image 1 of 3 Huawei Watch 2 Opening Procedure: step 3, image 2 of 3 Huawei Watch 2 Opening Procedure: step 3, image 3 of 3
      Tool used on this step:
      Buy
      • Use a pair of tweezers to remove the four plastic covers sitting next to the watch band holders.
      Ask FixBot
    4. Huawei Watch 2 Opening Procedure: step 4, image 1 of 3 Huawei Watch 2 Opening Procedure: step 4, image 2 of 3 Huawei Watch 2 Opening Procedure: step 4, image 3 of 3
      • Insert an opening tool into the gap between the back cover and the watch case at the bottom edge of the back cover.
      • Use the opening tool to pry up the back cover of the Huawei Watch 2.
      • Do not remove the back cover assembly all the way yet—it's still connected to the mainboard.
      Ask FixBot
    5. Huawei Watch 2 Opening Procedure: step 5, image 1 of 2 Huawei Watch 2 Opening Procedure: step 5, image 2 of 2
      • Carefully fold the back cover assembly to the opposite side of the two watch crowns.
      Ask FixBot
To reassemble your Huawei Watch 2, follow these instructions in reverse order.
4 other people completed this guide.
Dominik Schnabelrauch
266,477 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,895 Guides authored
3 Guide Comments
Tengo un problema con el reloj que no me esta haciendo las mediciones de la frecuencia cardiaca, como se cambia y donde se consigue ese sensor.
Gracias
Cesar Carrillo - Reply Share
Hi, any ideas if you can get the rubber membrane that goes behind the buttons? One of mine has worn away so had to swap them so the main button actually worked. Just bottom button now not working..
Andy Andy - Reply Share
A carcaça do meu HUAWEI WATCH 2 quebrou aonde o pino da pulseira encaixa. Como conseguir uma para reposição? Grato.
Del Credere Imóveis - Reply Share
Past 24 Hours: 4
Past 7 Days: 29
Past 30 Days: 141
All Time: 8,342
